Source for Upgraded X-Over Parts
[Deleted User]
[Deleted User] Posts: 1,223
edited March 2012 in DIY, Mods & Tweaks
I have a little side project I am doing that involves upgrading a stock x-over on a pair of bookshelves. I am looking for the preferred source to buy upgraded caps (Auricaps, SP?) and precision resistors ( 5w, 1 % range). Suggestions welcome and as always thanks in advance. Cheers. :cool:
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited February 2012
    Madisound.com i believe have the arura caps and mills resistors also clairity and some others.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • drumminman
    drumminman Posts: 3,396
    Parts connexxion has both, and auricaps are on sale currently at 40% off:
    http://www.partsconnexion.com/
    heiney9 Posts: 25,492
    Michael Percy audio carries Mills resistors and Auricaps.
    I have bought from Partsconexxion before and there service is pretty good. A friend of mine bought some stuff and specifically asked them to send it USPS which meant no duty tax. They sent it instead, without telling him, UPS and he incurred a large fee after the fact. So if you buy from them be aware this can happen.
    Michael Percy Audio is in the US.
    Why Auricaps? I use and love them for coupling but they are a bit pricey for x-overs. You can do just as good with other caps that cost less. Just, IMO. But the Auricaps sound very nice.
    P.s. If Auricaps are 40% off at Parts Connexion then it might be worth it even if you incur duty fee's from Canada.
    F1nut Posts: 51,951
    Look no further than Sonic Craft, http://www.soniccraft.com/
    Correction:
    Michael Percy audio no longer carries Auricaps. Sonicraft does.
    Parts Express does too as I physically picked up some Auricaps on way back from Ricardo's house in Ohio.
    VR3 Posts: 29,536
    I have found with Parts Connexion if you talk with CHRIS it usually goes smooth and STEPHANIE is fairly good too
    Auricaps are awesome but for the money Clarity Cap ESA all day every day
  • [Deleted User]
    On Auricaps - I had read some good things about them here but I am certainly not set on using them. I'll check out the others as well. It looks like I have a lot of options to look into. Again, many thanks to all, you guys never fail to disappoint. Cheers. :cool:
  • skrol
    skrol Posts: 3,460
    Just curious, what bookies are you upgrading?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • [Deleted User]
    skrol wrote: »
    Stan
    A pair of Def Tech Studio Monitor 450's.
  • skrol
    skrol Posts: 3,460
    That is quite an interesting speaker going down to 24Hz in such a small enclosure and the use of an aluminum dome tweeter. How do you like them?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • [Deleted User]
    skrol wrote: »
    Stan
    Not their finest work, IMO. Wanted to try the upgraded parts to compare before and afters. Like I said just a little side project. :cool:
  • [Deleted User]
    edited March 2012
    VR3 wrote: »
    Update - Placed an order with Partsconnexion and went with the Clarity Cap option. Waiting for the parts to come in the mail. I inquired about any "duty" before I ordered and they assured me there was none. Cheers. :cool:
    VR3 Posts: 29,536
    edited March 2012
    Hey Nap
    Wait until you hear the SM450 modified...
    I also highly recommend lining the enclosure with No-Rez...
    I could not even listen to those speakers unmodified... They are also my first set of speakers I modified that started it all!! lol
  • Face
    Face Posts: 14,340
    edited March 2012
    FYI, Madisound also carries ESA's, and shipping is usually cheaper.
