Parasound matched to LSiM lineup / Possible Onkyo Receiver / WPC
RocketOCannon
RocketOCannon Posts: 86
edited February 2012 in Electronics
Still looking and doing homework for soon to be HT
Would like some insight and opinions.
I am trying to get the right power matchup so I do to under power or over power the systems. I also don't know a lot about this...lol...hence the solicitation for "Help"..haha
I plan on two systems...due to layout in basement.
HT will be:
- est Room size / 14' W / 22' L
- 65" Panasonic coming out in March or the 65" VT30
- LSiM 707 Fronts
- 706C
- 703 Rears
- 702 surrounds...might buy now... might wait for down the road..TBD
- MicroPro 4000
- Probably going with Signal cables when ready.
Secondary system (Bar Side) 2 channel...just for music.
- Retro Pioneer SX-780 (Getting reconditioned now)
- LSiM 703
- This system I am going to find a vintage higher end amp..possibly a tube amp...down the road...might even get an old vintage Pioneer amp from the same time period
Dilemma;
- Any opinions about the two Onkyo receivers being considered?
- Thoughts on Parasound amps in general? I see nothing but good reviews.
- Will the Parasound A52 5 channel be a good fit for the HT? If paired with theory Onkyo 3009 or 5009 will get me to about 260 WPC....the next Parasound 5 channel amp is 250 wpc. If and when I go to the Surrounds...i would step up to a 7.1. As of right now I can buy the Parasound and Onkyo new at great prices due to a connection.
- Will the Parasound A23 (125 wpc) be a suitable fit and power for the SX-780 (45 wpc)? Should get me about 170 wpc.
HOME THEATER 5.1
JVC DLARS56U
92" SI Black Diamond 1.4 16:9
NAD M25 MC Power Amp
Marantz AV7005 Pre Amp
Oppo 95
LSiM 705 Fronts
LSiM 706c
LSiM 703 Rears
SVS PB13 Ultra sub
ZONE 2
LSIM 707 (2 Channel Sessions)
McIntosh MC312
McIntosh C49 Preamp
Marantz SA8005 SACD/CD Player
79' Pioneer SX-1080
Furman Elite 15 PC
SolidSteele HF-4 series rack
REL Carbon Special Purple Label
(Building system out currently)
(Use Quobuz almost exclusively - CD/SACD Part time)
OUTDOOR DECK
NAD C 375BEE DAQ
PSB CS 1000 Speakers
Sonos
Signal Cable - Ultra Single (Banana), Magic Power Cord, Dig Power, Vid Power.
RTi T3-V+, SONOS, Furman Power Conditioner
Post edited by RocketOCannon on
    F1nut Posts: 51,672
    You cannot over power.
    It doesn't work like that. You cannot use the amps in the AVR in addition to the Parasound. It would be the Parasound only for power.
    Again, it doesn't work like that. In addition, that old receiver does not have pre outs, so you cannot add an amp to it.
  • RocketOCannon
    Thanks F1...was worried it was like that.
    so..If I have a receiver that produces **** wpc...what do you use in addition to amplify power to a suitable level for the speakers and system?
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
    EndersShadow Posts: 17,687
    Normally you get a receiver with pre-outs which allow you to connect an external amp to provide power to the speakers. So in effect your using the receiver only for its video/eq capabilities, and an amp for the power.
  • RocketOCannon
    So...would the Parasound A51 @ 250 wpc x 5 be more suitable for this potential system? To drive the LSiM 707s?
    ..and if I understand it...then as far as the receiver goes...the wpc is rather insignificant vs the features and quality??
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
    F1nut Posts: 51,672
    That amp would do quite nicely.
    Correct, the AVR would only be used as a pre/pro. The quality of the pre amp section will matter. You might want to consider a dedicated pre/pro.
  • RocketOCannon
    ..and so the clouds open up to a world of understanding! lol..
    Thank you F1...any other thoughts on my plan? Suggestions? Watchouts? I appreciate the help...been doing tons of reading, going in circles.
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • kawizx9r
    kawizx9r Posts: 5,150
    +1 for the dedicated preamp/processor.
    If you're going to spend good money, don't worry about the amp section/power of a receiver. Try to find one that'll sound good and fit your needs such as number of HDMI ins/outs, 3-d capability, wireless capabilities, or whatever you might want or need. Most higher end receivers will have preamp outputs, if you're not sure just ask on here.
    PS Why go with the MicroPro 4k? Don't get me wrong, I owned a 1000 and heard a 3000 in an HT environment and they can put out an ample amount of bass. If this setup is going to be more of an HT system, I recommend looking into Epik or SVS for your movie needs!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • chumlie
    chumlie Posts: 8,658
    Take a look at Pioneer sc series for pre/pro with Parasound.
    F1nut Posts: 51,672
    Since you asked. You might want to consider the DSW Pro 660wi sub instead of the 4000 as ported subs seem to be favored for HT only rigs.
    I wouldn't bother trying to use that old receiver to drive the 703's, it wouldn't do them justice.
    Cables matter and it appears you have the coin, so I'd suggest looking at something better.
    Just one other thought. If you went with the LSiM's, Parasound amp and a nice pre/pro it would also make for a decent 2 channel set up. Unless you really want two rigs, that is.
  • DMara
    DMara Posts: 1,434
    If you are going to use an amp to power the speaker, then go with a dedicated pre/pro to avoid wasting the AVR's amp section. That was why I replaced my Denon AVR-4810ci with an Integra DHC-80.3.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • Big Dawg
    Big Dawg Posts: 2,005
    Hey ROC, there is an active member on these boards, Mantis (Dan), who sells nice gear in Eastern PA, and he could probably help you audition some of the equipment you are considering.
  • Big Dawg
    I think this is a great point, plus you could eventually get a nice tube amp for the fronts and use the Parasound for the other 5 channels when you add the surrounds.
  • RocketOCannon
    Great points by all.
    KawizX - I have considered the SVS sub...just have a much better relationship that will net a ridic price for a new PA Micro. I hear nothing but great things about those subs.
    CHUM - I wanted the Pioneer SC -37 used...but....I can get new for a used price if I go with Onkyo.
    I would prefer the Pioneer SC-37 or SC-57
    F1 - Agree and understand about the SX-780...I might just hook it up to a little 3rd rig with some basic Energy bookshelf's and let the kids play with it. Thats my original college stereo from back in the day and just can't part with it...It's out right now getting refurbed. I am going to try and get the $ for a SX-1980(270 wpc) or 1280...but thats gonna have to wait
    I admit, I really don't understand the pre/pro stuff......If this is a more prudent approach, I would look at the Parasound Pre's.
    Pre/Pro /AV REC relationships....If any of you can spell it out like your talking to a kid...please do. Once I know what I need to buy component wise, I can do the homework and look for used gear to save a little $.
    I would LOVE to be able to speak with Dan/Mantis or anyone that lives in E. PA or NJ or nearby. I could always meet a polker at a higher end store or whatever. Obviously I have some questions.
    Thanks guys for your time, patience and expertise.
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
    tonyb Posts: 33,065
    Yes and yes.
    A pre/pro is basically a receiver minus the applifiers. They have no built in amplification what so ever. So if you want 5 channel surround, you'd need a 5 channel amp. 7 channel surround- a 7 channel amp. But normally pre/pro's are built better than a receiver in general.
  • RocketOCannon
    In an effort to save some cash and put it to use on all the other stuff I need to buy for a new basement....
    Thoughts on this for amp and pre/pro...
    If I don't go with the Pioneer SC57 or Onk 5009... would this combo be better then going with one of those AVs?
    -Parasound 5250 V.2 I can get this for well under MSRP (I drool for the Halo A51...but thinks it's gonna be hard to find one at a steal price)
    - Marantz 7005 pre/pro (Can get it for just over $1,000)
    Thoughts?
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • codyc1ark
    codyc1ark Posts: 2,533
    Very nice system you are putting together. I second the sub suggestion, take a look at elemental designs, outlaw, hsu, and epik. The two most important components IMHO in an ht system are the center and sub. With that kind if system, I'd want to run dual subs. Heck, I want to do that in my lil system... Good luck, you may be chasing your tail for a few weeks on the question of where to go. If the new Outlaw pre ever comes out, I'd weigh that as a pre option or even look at the new anthem line of pre's. Again, GOOD LUCK!
  • RocketOCannon
    Thanks Cody...can't wait till the day I can settle in to sonic nirvana. Whatever I do now is just a baseline for improving later on. If I like the sound...great I will stick with it.
    Again...I am drawn towards the SVS subs...i know they rock...but I can get an overall better deal by going with the PA Micros.
    My challenge right now is ...AV or pre pro?? Im really looking at something like the Marantz 7005 Pre at a value/performance price would be a better starting point overall then going with the Pio 57 or Onk since it puts me in the Pre +Amp world...but if it does not have the needed quality to mesh with the overall system...then...maybe I rethink it. Im going to still keep my eye out for the Halo A51 but wonder if anyone has any opinions or experience with the re designed Parasound 5250 V.2
    Keep the thoughts coming boys! You have all been very helpful!
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • RocketOCannon
    My challenge right now is ...AV or pre pro?? Im really looking at something like the Marantz 7005 Pre at a value/performance price. Would this be a better starting point overall then going with the Pio 57 or Onk since it puts me in the Pre +Amp world? ...but if it does not have the needed quality to mesh with the overall system...then...maybe I rethink it. Im going to still keep my eye out for the Halo A51 but wonder if anyone has any opinions or experience with the re designed Parasound 5250 V.2
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • RocketOCannon
    Anyone have any thoughts to
    AV - SC-57 or Onk 5009 VS ....Seperates / Parasound 5250 V.2 matched with Marantz AV7005 Pre?
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • niente
    niente Posts: 68
    Can't speak to the Pre's but the Para 5250 (mine is older version) is just super
    I would like to go with a Pre Amp Proc in place of my Onk AVR some day--PLease let us know what you choose--and why!
    Sounds like a great "cave" yoursetting up!
    Onkyo TX-SR804 receiver
    Parasound 5250
    LSI 15's
    LSI C
    LSI FX's
    PSW1000 Sub
    OPPO 93
    Sony CDP-C315 CD
    Monster AC line cond
    Audioquest, Blue Jeans & Monster wires/connects
    40" Sony Bravia XBR6
  • RocketOCannon
    Thanks, niente...Once I do my shopping I will def let the PA club know what i did and send some pics.
    Also, other then the Marantz AV7005 (New).... - Does anyone have any ideas for a used pre amp that would compliment my planned HT for a used price in the $1,000 range....I would go as high as $1,500 if it's a steal. Obviously I can get more bang for buck going used....I just don't know JACK about Pre's and what to watch out for...
    Please list some specific model #s for pre amps that i should look at for consideration
    Which Parasound Halo Pre or other would I use is this system?
    Thanks,
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • RocketOCannon
    Team PA,
    An thoughts on a Pre for my setup? I know nothing about Pre's.
    Please see my last post...will spend up to $1,500 used or new.
    Thanks,
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
  • RocketOCannon
    Any thoughts on the Adcom GTP--870HD Pre/Pro? Audiogon -$1,000
    Vs "New" Marantz 7005
    Does this have the essentials/features I would need to run my potential system including the new Panasonic VT50 65Plasma?
    I need some help her Polkies...I am like a deer on the O'Hare runway when it comes to the details and pre's/features etc.
    Thanks,
    HOME THEATER 5.1
    JVC DLARS56U
    Oppo 95
    LSiM 705 Fronts
    LSiM 706c
    LSiM 703 Rears
    SVS PB13 Ultra sub
    ZONE 2
    McIntosh MC312
    McIntosh C49 Preamp
    79' Pioneer SX-1080
    Furman Elite 15 PC
    OUTDOOR DECK
    NAD C 375BEE DAQ
    Sonos
