5A or 5B
Barcus1963
Barcus1963 Posts: 25
edited February 2012 in Vintage Speakers
Ok looking at some of the post here on this board I noticed that the Monitor 5 series speakers are completely different in design.
Does anybody remember why Polk overlapped the midwoffer to the PR?:question:
Post edited by Barcus1963 on
  • HTguru1982
    HTguru1982 Posts: 1,066
    Early 5B's, I believe. The 5A's had the Peerless tweeter. The later versions of the 5B's used the SL2000.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • Barcus1963
    So how would I make sure that the tweeter was not replaced with an Sl1000?
    Would I be able to ck the crossover?
  • Barcus1963
  • skrol
    skrol Posts: 3,460
    That is interesting. I thought that only the 5A had the overlap PR and MW and the badge mounted to the bottom of the cabinet and either the SL-1000 or Peerless. Any idea what the mfg date was?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Barcus1963
    skrol wrote: »
    Stan
    There are no other badges on these speakers.
    No stickers othere than whats on the terminal caps
  • TennMan
    TennMan Posts: 1,266
    Barcus1963 wrote: »
    It looks like a sl1000 to me. The peerless has a black dome and face plate. The sl1000 is silver with a clear dome like the one you have. If you want to verify, remove the four screws holding the tweeter in, remove it and read the sticker on the back.
    heiney9 Posts: 25,497
    See the sticker that says "5B"? Guess what, it's a 5B. Lots of variations of 5B's. My pair of 5B's had the sl2000 tweeter with a single fuse (now completely bypassed) but my cabinets are the newer cabs with the beveled edges. If I had to guess yours are a bit of a transitional model since they have the older cabinets and overlapping mid and passive you typically see for the 5A's. If you care to pull the midwoofer I'd be interested to know the model number MW6500, 6501 or 6502.
    The tweeter is an SL1000.
  • Barcus1963
    heiney9 wrote: »
    It has a 6500 MW:mrgreen:
  • Barcus1963
    Now getting back to the OP, what was the reason for Polk to overlap the MW to the PR?
    Anybody know?
    If the MW6500 is genuine and not a replacement, everything on the surface points to it being a 5A, but Polk had so many transitional pieces that it is likely they ran out of 5A x-overs and used 5B x-overs to finish the run, so to speak. I wouldn't worry too much as the biggest differences in sound were the tweeters.
  • Barcus1963
    heiney9 wrote: »
    I love the way these sound!
    These Kick Butt
