5jr+ mod ?
soundfreak1
About to start the mods on a pair of 5jr+ . in the sched. it shows a rde050a saftyswitch. is this the much milined poly switch? if so should it by removed and bypassed or would a fuse be put in instead?
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
Yes, that should be the polyswitch. You can replace with a jumper.Jay
Tjanks i thougjt so just wanted to confire. Thanks againMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Not sure if this helps but here's a detailed thread on a 5 upgrade.
http://www.polkaudio.com/forums/showthread.php?51420-Monitor-5b-s-x-over-upgrade-w-pics&highlight=upgradeMonitor 7C's With Tubes
