purchased surroundbar sda need to hook it up to panasonic plasma 3d viera tv
bignasty
bignasty Posts: 5
my tv has video in audio left and right and a video jack is this where i hook up surroundbar theres no headphone jack and instructions say Line Audio or Headphone Audio output jack.please help
Post edited by bignasty on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited February 2012
    Hello,
    Thanks for posting. Is there an audio "output" on your TV?
    Regards, Ken
    F1nut Posts: 51,866
    On the left side of the TV there is an "Digital Audio Out". Use the optical adapter cable that comes with the TV to connect with a regular optical cable.
  • bignasty
    bignasty Posts: 5
    no there is not unless you mean the red and white audio maybe you could look online at the back of my tv its a panasonic viera 50 inch plasma 3d has three hdmi a component usb dongle please help the optical cable is not a option the soundbar has no hook up for optical plus i didnt get one with the tv
  • bignasty
    bignasty Posts: 5
    my soundbar has no optical hook up just red and white plug in with red white to tv will that work
    F1nut Posts: 51,866
    Exactly which model TV do you have?
  • [Deleted User]
    Hello,
    In looking at the owner's manual for the Panasonic Viera 50, class S30 series there doesn't appear to be any outputs for audio. If you gave us the complete model number for your unit we could check it specifically. You might need to connect the SB to another component, such as your DVD/Blu-ray player or cable set top box.
    Ken
  • bignasty
    bignasty Posts: 5
    Panasonic TC-P50ST30 is the exact model ive found on amazon some converters optical to analog just ive been told that i need one that is at least dolby 5,1 so confused now lol
  • [Deleted User]
    Hello BN,
    Thanks for the additional information. The Panasonic has a digital audio output, but the SurroundBar SDA is an analogue device. The best choice would be to exchange the SB you have for either the SurroundBar 3000 or 4000 or 6000. These have digital audio input capability and should make connecting easy. You could use an external digital-to-analogue converter, but that would be diluting the advantages digital sound can offer.
    Regards, Ken
  • bignasty
    bignasty Posts: 5
    ok thank you for your time
