What 5 channel amp???
Systems
Systems Posts: 14,872
edited April 2004 in Car Audio & Electronics
Out of the amps listed at the link below, what amp do you think is the best? What amp should I stay away from? I'm trying to not to spend and arm and a leg, but I want it to be a worthy purchase. Other amp suggestions are welcome.
http://www.acaraudio.com/default.php?cPath=22_35&page=1&sort=4a
System will consist of: 5.25 component set (front), 6 x 9 coaxils(back) and one 12" sub.
or this older MTX amp I saw on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39742&item=3090020689&rd=1
Thanks.
Testing
Testing
Testing
  • jamas33
    jamas33 Posts: 89
    edited April 2004
    That Kenwood Excelon listed at 449.00 you can get much much cheaper at www.discountjungle.net I think its 288.00 there.. at 288. thats the best value.. I would like that Hifonics for 309
    Equipment List:
    Head Unit: Kenwood Excelon XXV-005
    Planet Audio P13.3
    Ipod 60 GB
    XBox
    AMPS:
    Kicker KX1200.1
    Kicker KX850.4
    Speakers:
    Front: Kicker RS65
    Rear: Kicker RS65
    Rear Deck: Pioneer 4x10 (AAARGH)
    Subs: 2 Kicker 15L7
    my car: http://www.cardomain.com/ride/571313
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2004
    When in doubt go with Precision Power but ONLY the PCX line. The newer DCX stuff is poo-poo.
    JL Audio's would be my 2nd choice but it doesnt a good sub end (250 rms)
    The Kicker would be my 3rd choice.
  • exalted512
    exalted512 Posts: 10,734
    edited April 2004
    if money is no object:
    1. JL 500/5(i know i know...but the 100x front 25x2 rear is really cool! too bad it had to be JL to think of it...)
    2. PPI PCS5800
    3. Crossfire VR705D
    4. Kenwood eXcelon KAC-X650D
    5. PPI DCX800.5
    6. Soundstream RUB555
    7. Phoenix Gold R9.0:5
    8. Hifonics Zeus ZX8000
    9. Eclipse PA5532
    10. Alpine MRV-F450
    11. Kicker KX700.5
    12. Soundstream PIC5.700(what really hurts this one is the 150x1 sub channel)
    13. MTX Thunder895
    best for the money(another words, what i would get from 1-12)
    1. Phoenix Gold R9.0:5
    2. Hifonics Zeus ZX8000
    3. Alpine MRV-F450
    4. Soundstream RUB555
    5. Kenwood eXcelon KAC-X650D
    6. Crossfire VR705D
    7. Eclipse PA5532
    8. PPI PCS5800
    9. Kicker KX700.5
    10. Soundstream PIC5.700
    11. PPI DCX800.5
    12. MTX Thunder895
    13. JL 500/5
    **notice Ample Audio is not included
    why?
    because they suck
    and I would get a 2ohm sub
    you can get more watts out of your amp that way
    more watts is always better:D
    wow this took a long time
    hope this helps
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2004
    that mtx blue thunder amp will rock your world and then some....
    realistic power output is about 65-75 x 4 @ 4 ohms and 300 x 1 to the sub @ 2 ohms ... damn fine choice in my opinion for 197 bucks.
    far as anything else... JL has a 100 x 2 + 25 x 2 + whatever x 1 for the sub ???? damn, they really did have a good idea with that one....
    Lightning audio does a couple that are like that -- 150 x 2 to the front and 65 x 2 to te back... but w/ out a sub .
    The Artist formerly known as PoweredByDodge
  • PoweredByDodge
    edited April 2004
    upon looking at your full list -- if u have the 400 bucks, get the soundstream.
  • Systems
    edited April 2004
    Thanks for the responses guys. I'm still debating if I should go for a 5 channel amp or just use the kicker sub amp I already have and buy a 4 channel amp for the other speakers. Thanks again -Rob
    Testing
    Testing
    Testing
  • exalted512
    edited April 2004
    if you already have an amp just get a 4 channel
    Kicker makes nice four channel amps as well
    -Cody
  • Systems
    edited April 2004
    I was gonna just get another amp, 4 channel, but i didnt want to go through the trouble of wiring another amp up. i guess i shouldnt be lazy..lol.. one amp is just an easier setup, now i'll need a distribution block, and another wiring kit..etc... but like you said, i already have a kicker amp for the sub so i might as well use it,instead of selling it. :)
    Testing
    Testing
    Testing
  • Systems
    edited April 2004
    indecisive
    Even though this is refurbished by Kenwood what do you guys thing, being I have a kenwood excelon deck and would be able to use the advanced bass management BS that the deck has.
    http://www.discountjungle.net/kenkac60wx42.html
    Would I be crazy for not using my small Kicker sub amp(KX 150.2) that I already have for my 12" sub with another 4 channel amp for the other speakers? i'm leaning towards the 5 channel amp again, mainly cause of less space consumption, only one wiring kit needed, and quicker hookup.
    People that have there 6 x 9's amped, is it worth the amp power over the HU power? I am def. amping my component speakers.
    Sorry to be such a pest. Thanks for the help.
    Testing
    Testing
    Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    yeah, it's worthwhile to amp anything; especially 6x9's that have good bass capability.
    amp choice - hey, it's your car; if space is a concern, ebay the kicker and get a five channel; if you want to spend a little less and do some more work, go with the 4. all up to u.
