Polk Audio 40s with stand or 50s without?
Senzo Tanaka
Senzo Tanaka Posts: 9
edited February 2012 in Speakers
I'm racking my brain here trying to decide what to get for my surrounds.
My options are Monitor 40s with a stand or Monitor 50s as-is.
My dilemma is the height. Ideally, I believe a rear speaker should be anywhere from 2-3 feet above ear level or at least the tweeter at the same level.
Every stand I've found that would work with the 40s is only around 30" tall and my sitting height is around 43". The Monitor 50 sits at right around 43" as a tower.
Neither option apparently is going to be anywhere near 2-3 feet above ear level. Are there any stand anyone that can recommend that are taller/adjustable or should I go with the Monitor 50s and find a way to lift them a bit higher off of the floor (which may look weird)?
I don't want to wall mount so if anyone has any suggestions, please advise.
Post edited by Senzo Tanaka on
    EndersShadow Posts: 17,707
    Well you cant always have ideal, sometimes you simply have what you have. The 50's without stands are much easier to manage. I ran Monitor 60's and R50 towers as surrounds for a long time for the same reason. I now have different surrounds mounted on the wall and while its better its not by any ridiculous margin.
    Set it up how you can and enjoy :smile:
  • Geoff4rfc
    Geoff4rfc Posts: 2,850
    My thoughts exactly!!!!!!!
    Welcome to the forum Senzo!!
    I have made my own stands for both my 30's and my 40's. That way you can have them any height you want them. I've seen some guys doing 50's as surrounds and lifting them a bit.
    I'm currently using my 70's as surrounds and just having them stand as they are and I'm really enjoying them. Never allow yourself to be limited by what you see, as the old saying goes, "where theres a will theres a way". And as EndersShadow said, "Set it up how you can and enjoy"
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
