Just a quick capacitor application question
heiney9
heiney9 Posts: 25,486
edited February 2012 in DIY, Mods & Tweaks
I am getting ready to purchase the final parts to upgrade the x-overs in a pair of RT25i bookshelf speakers.
Schematic here
http://www.polkaudio.com/forums/attachment.php?attachmentid=18701&d=1155781569
For the low pass, obviously these don't go that low because of the driver size, how much influence on the overall sound does the 27uF cap have? Does it affect more midrange than bass? The reason I ask is I was going to buy AXON 27uF caps since they are economical. If that 27uF cap has a lot of influence on the voicing of the speaker I suppose I could step up to a better cap. I am using Clarity APW for the high pass section. The parts need to be an improvement, but also economical and as physically small as possible.
My other thought is to just do the high pass and leave the rest? Any opinions on that?
Post edited by heiney9 on
    FWIW, I am super impressed with these little bookies, they do so much right. I am amazed at the sound that comes from these. I think they are more neutral than the RTi38's I also have been demoing. Impressive little speaker and I don't want upset the balance, but they are just a tad ragged on top. I am hoping a better cap and Mills resistor will correct that.
  • CoolJazz
    CoolJazz Posts: 572
    Looks like a resonate trap. So maybe not quite as audible as the main filtering caps, but I wouldn't say invisible at all either.
    Don't know that helps so much...
    CJ
    PS...wouldn't be involved with the ragged your talking about i don't think.
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    CoolJazz wrote: »
    CJ
    No the raggedness is in the high pass. I just am not sure on small speakers if the low pass section has a large influence on midrange as well.
  • FTGV
    FTGV Posts: 3,650
    CoolJazz wrote: »
    It's a Zobel for impedance equilization plus forming the shunt leg of the low pass section.
    FTGV wrote: »
    You think using a premium poly cap would have much influence vs. a budget poly cap like the AXON? Or maybe just leave it be and concentrate on the high pass?
  • FTGV
    FTGV Posts: 3,650
    heiney9 wrote: »
    IMO a budget poly would suffice in the low pass section.Another budget option. http://www.erseaudio.com/MPX25-03-27-00 I'm going to be trying some of these soon in both hi and low pass sections.
  • CoolJazz
    CoolJazz Posts: 572
    FTGV wrote: »
    Thanks...that was what I was thinking of and had brain freeze and couldn't think of the term Zobel. It'd most likely be keeping some control at the port freq wouldn't it?
    CJ
  • FTGV
    FTGV Posts: 3,650
    CoolJazz wrote: »
    When placed across the voice coil of a woofer it reduces the inductance that causes impedance to rise as frequency increases.Basically making the driver look more like a resistor to the crossover by making the impedance of it's voice coil more linear.
    Thanks Fred, I know Solen and AXON are essentially the same cap. Isn't Erse made by the same factory as well? Now it's a toss up between those two, because the Solen of the same value (except higher voltage) is twice the price of the AXON and Erse. I had Solens in the high pass of my 5B's and I like the Clarity PX much better for my situation.
    I don't think Parts Express sells a Dayton in the exact value I need. I'll have to check again.
  • FTGV
    FTGV Posts: 3,650
    heiney9 wrote: »
    Im not sure if ERSE also sources from SCR like Axon and Solen.I think either would suffice for low pass duties.
    VR3 Posts: 29,496
    I have used the Pulse X from Erse with positive results... very nice caps...
    I have no used Axon though ---
