what are the odds of this?
ravaneli
ravaneli Posts: 530
edited February 2012 in Speakers
First I get my brand new A7s with that tube fallen off
http://www.polkaudio.com/forums/showthread.php?129291-oh-horror!-It-came-broken!-What-do-I-do
and yesterday I go and I grab a pair of f/x500 from craigslist that looked like the box was just opened. I didn't even bother to check if they work. I go home and as I am about to plug them in I feel something rattling inside.
Now I am wondering if the guy had the rattle and that's why he got rid of them so cheap. They play and look like new (once I glued the tube back on) and came with GORGEOUS WOOD STANDS.
BlueFox wrote: »
I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
But as in all things your perception is your reality.
Post edited by ravaneli on
    VR3 Posts: 29,549
    thats great - atleast these are easy fixes ;)
  • pyrocyborg
    pyrocyborg Posts: 524
    Man, you're really unlucky... I hope there is nothing else, and that you fixed everything!
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
  • Geoff4rfc
    Geoff4rfc Posts: 2,958
    pyrocyborg wrote: »
    On the contrary, I'd say he was pretty lucky indeed. The loose tube got him a pretty sweet deal and no performance was sacrificed.
    Now, if I can just find someone trying to sell some LSiM's with a slight rattle................
  • polkfarmboy
    polkfarmboy Posts: 5,703
    We should hang out :lol:
  • halo71
    halo71 Posts: 4,638
    I've never heard of anyone gluing binding posts back on before. :cheesygrin:
    --Gary--
  • jbooker82
    jbooker82 Posts: 1,627
    Let us know what you think of those FXI's they are a nice surround speaker.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    Tony M Posts: 11,727
    I love these easy fixes!!
    I've had my share of reglueing port tubes. "Aileenes" (sp) glue works great.
  • ravaneli
    ravaneli Posts: 530
    can I use the f/x i 500 for fronts?
    They say surround, but i only have the RM7 set for fronts.. and I can't have these for surround with my small RM7 for fronts..
    Also what does dipole/bipole even mean? I saw the switch when I disassembled the speaker but I have no idea what it does..
    BlueFox wrote: »
  • Geoff4rfc
    ravaneli wrote: »
    What happened to your A7's, I thought those were going to be your fronts????????
  • Geoff4rfc
    Check it out DSkip, look at the 1st post, this guy just got brand new RTiA7's. I'm curious why those aren't being used as his fronts.
  • jbooker82
    What happend to the RTI A7's?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • ravaneli
    ravaneli Posts: 530
    OK, i bought the A7s for HT and the living room, but I hooked them to my PC in my bedroom and now i can't let go of them. The thing is i spend 90% of my time in my bedroom, playing PC games or listening to music. I LOVE the A7s with the A6, and don't want to put them in the living room, where I only watch TV while I have dinner.
    So the A7s and the A6 displaced the front 3 of my my RM7, and i don't need the DSW 660 pro either. I like how the my new front 3 make less bass, but make it super crisp.
    So the f/x 500 and the front 3 from the RM7 are going to my living room, along with the 660 sub. But I don't know if I should put the big f/xi on the front and get advantage of their size and lower range, or put them on the back the way they were designed, and have a tiny RM7 satelites for front. See my problem now?
    BlueFox wrote: »
  • Geoff4rfc
    You crazy man, but it's okay. Can't blame you for wanting the best where you hang the most.
    Go ahead and use the F/X500 as mains, the worst it can do is sound good. You have options, just listen to the speakers, swap 'em around and see what works best where.
  • gdb
    gdb Posts: 6,012
    I think Q Control needs a Leroy Jethro Gibbs head smack, badly.
