MOMO MMC650 or Infinity kappa 62.5i
Systems
Hi, I really don't know which speaker I should go for. Has anyone had experience with either of these speakers. I would really appreciate any personal oppinions.
thanks,
nic
thanks,
nic
Testing
Testing
Testing
Testing
Testing
Momo, Momo, Momo!!! 'Nuff said!
The Infinity isnt a bad speaker but its a very bright sounding one and can sound very "tinny" with metal or hard rock. If youre into jazz or rap then the Infinitys are fine but if you like anything with heavy guitars you wont dig em. Plus the bass response is pretty lame as well.
The Polks on the other hand are very warm sounding. They have some of the smoothest highs around and work great with virtually all kinds of music. They can handle a lot of power and sound great at loud levels. Yessir, its hard to beat the Momo line without getting into a much higher price range.polkaudio sound quality competitor since 2005
Thanks so much for being so detailed. I've heard good things about both of these speakers. They're for a boat, so I don't really need the absolute top of the line, however I do want a top notch speaker.
Momos are higher priced, do you think that is justified?
thanks,
nicTesting
Testing
Testing -
it depends on you; with the polks, you're paying more for a better speaker. if the sound on the boat doesn't have to be amazing, go with the infinitys and save some money.
btw, the bass response bit is important in the open-air environment of a boat.It's not good, very fundamentally simply not good. - geolemon
I don't mean to sound like a noob, but I guess I am. What does is the bass response bit?
thanks,
nicTesting
Testing
Testing -
bass response=how much bass
more bass response=more bass
I would still go with the Polk. The Infinity will not sound as good at a high volume as the Momo would. Since youre going to use em on a boat you will probably be playing them louder than someone in a car would.polkaudio sound quality competitor since 2005
ever noticed that you hear less bass when you roll the windows down? in a boat, there's way less enclosed space than in a car, so you need much more powerful bass to hear it at the same level as mids and highs.It's not good, very fundamentally simply not good. - geolemon
Cool, you guys convinced me...that was easy. They're only $20 buck more per pair anyway...not like it's a big deal. Besides the momos look awesome as well, which is a nice little side bonus.
thanks again for all your help...if you guys need any boat help let me know.
Have a good one,
nicTesting
Testing
Testing -
hey, i understand his sn now! anyway, glad we could help
I'll post some pics in about a week, to show what your advice looks like in a boat.....they'll look and sound great I'm sure. I've got a huge install ahead of me....Well the shop does, should I say. 4 interior speakers(momos), head unit, 10 disc changer, 2 amps, tower speakers, 2 wired remotes, sub and box.
thanks again
nicTesting
Testing
Testing -
tower speakers??It's not good, very fundamentally simply not good. - geolemon
They're the speakers that fit on top of the wakeboard tower.Testing
Testing
Testing -
Hey guys....one more noob question if you don't mind. In the picture of these speakers what is the littel square shaped thing...is it the external crossover? If so, what does it do and where does it go or mount?
thanks,
nicTesting
Testing
Testing -
yeah, i believe thats the external crossover youre looking at
it seperates the high frequencies from the low frequencies and sends the highs to the tweets, lows to the mids
you put it anywhere b/t the amp and the speaker, or the headunit and the speaker if youre not using an amp
Does it have to be visable to the speakers?Testing
Testing
Testing -
If you are having professionals install the system. Then dont worry about where what when those crossovers go. They will install it properly. If you need any help and is in the southern california area let me know. I know guys that install sound systems in boats, rv's and other things. Email me jamas33@hotmail.comEquipment List:
Head Unit: Kenwood Excelon XXV-005
Planet Audio P13.3
Ipod 60 GB
XBox
AMPS:
Kicker KX1200.1
Kicker KX850.4
Speakers:
Front: Kicker RS65
Rear: Kicker RS65
Rear Deck: Pioneer 4x10 (AAARGH)
Subs: 2 Kicker 15L7
my car: http://www.cardomain.com/ride/571313 -
noOriginally posted by malibu
