Which DAC...
  • Jason_k
    Jason_k Posts: 110
    edited February 2012
    I bought the W4S DAC 2. Very pleased with it.
  • Face
    Face Posts: 14,340
  • vcwatkins
    vcwatkins Posts: 1,992
    Yep, sounds lovely, I'm sure. But I'm struggling with the $1,000 upcharge. Will likely take the "cry twice" path.
  • nspindel
    nspindel Posts: 5,343
    +1 for the Wyred4Sound DAC2. I've had it for a while and have been thrilled with it. I've yet to read anything from an unsatisfied owner. I bought it about a year ago and haven't looked back once. And it's an American company, remember!
  • markmarc
    markmarc Posts: 2,309
    The Sim Audio D100 is a definite finalist for the budget conscious audio fanatic.
    Former Staff Member TONEAudio
    2 Ch. System
  • audiocr381ve
    audiocr381ve Posts: 2,588
    nspindel wrote: »
    If I had your budget, I'd be all over the Wyred4Sound DAC2.
  • Beta
    Beta Posts: 267
    +1 for the Wyred 4 Sound DACs.
    I used a W4S DAC 2 in my rig for a year and found it to be a stellar performer. I use horn loaded speakers. In an effort to take the "edge" off, I was running my DAC 2 through a Audio Horizons TB 5.1cv tube buffer with Siemens E83CC tubes.
    I must admit, the sonics were superb. The downside was that I had too many cables in my system. I was running a pair of MIT Shotgun S1.3s from the DAC 2 to the tube buffer and then a pair of S1.3s from the tube buffer to a Parasound Halo JC 2 preamp and then a pair of S1s from my preamp to my tube amp.
    I recently moved out the DAC 2, JC 2 and Audio Horizons pieces and acquired a Peachtree Audio Grand Pre preamp. Since the Grand Pre has a built in DAC, I now only have three ICs in my rig. I run a Wadia iTransport to the Grand Pre via an MIT Magnum Digital IC and I run a pair of S1.3 ICs from the Grand Pre to my tube amp.
    This simplification and elimination a cabling has made a significant positive improvement. I owe a debt of gratitude to one of our forum members for politely nudging me towards moving to a rig with less cabling.
    I have been running the Grand Pre in my system for about a month now. The W4S DAC 2 is a great DAC. However, to my ears, as far as overall performance goes (soundstage dimensionality and warmth), the Grand Pre beats my prior set up. This is with the stock tubes in the Grand Pre. I have ordered a pair of Genalex Gold Lion 12AX7 tubes. I can't wait to hear the result of rolling out the Grand Pre's stock tubes and replacing them with the Gold Lions.
  • cstmar01
    cstmar01 Posts: 4,424
    Thanks for the info guys. Ill get a wyred dac2. I just bought a pair of tube mono blocks so I'm going to have those in the system for a little bit before I jump on a dac as well.
    I still like the PS pwd which is supposed to be close to the sound of the wyred so o figured I could save a little and go that route.
  • nspindel
    You will not look back after you get the Wyred. Built like a tank, sounds incredible, holds it's value, and American made.
  • thsmith
    thsmith Posts: 6,082
    I have had my DAC 2 since early December and it just sounds better and better. Has over 600 hours on it. I feed it into my tube preamp that does not support a remote, the DAC 2 remote work great but I never go above 45.
    Used a ps audio pc since day 1 and just added a hifi tuning supreme fuse. I was surprised to find a ceramic gold end fuse already in the DAC 2.
    I had a ps audio DAC iii for about a year.
  • 98Badger
    98Badger Posts: 317
    cstmar01 wrote: »
    I've had the opportunity to compare the W4S and PWD head to head with the same gear. Sonics are nearly identical. The perfect wave does spread instruments over a wider soundstage. Both are excellent!
  • thsmith
    98Badger wrote: »
    We're both dacs burned in? The DAC 2 does not come into its own until has 250-300 hours.
  • W WALDECKER
    W WALDECKER Posts: 900
    I have the Eastern Electric Minimax with upgraded opp amps and a Acme Audio Labs siver fuse and i am very happy with it.
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • rickrick37
    rickrick37 Posts: 10
    North Star DAC 32 with the best C/P value!
