Piano Gloss like finish
tommyt21
I am building some shelfs for my blurays this weekend and would like them to match my tv and entertainment center. What is the best method to achieve a "Piano gloss like" finish? The wood I got is 3/4 X 8 select pine it was $16 a plank. It seems like high quality wood.
ps would like to either do black or a dark walnut
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Fronts: RTi A7's
Surrounds: Rti A3
Post edited by tommyt21 on
seem to be some good instructions here:
http://www.lungster.com/l/speakers/pianofinish.shtmldesign is where science and art break even. -
There is a ton of info out there on the subject.
See here: https://www.google.com/#hl=en&tok=Dm6ikN0iwBRpP9Krq40Xiw&cp=3&gs_id=4m&xhr=t&q=how+to+acheive+piano+finish&pq=best+wood+to+acheive+piano+finish&pf=p&sclient=psy-ab&source=hp&pbx=1&oq=how+to+acheive+piano+finish&aq=f&aqi=&aql=&gs_sm=&gs_upl=&bav=on.2,or.r_gc.r_pw.,cf.osb&fp=34ec4ed5805c27c5&biw=1440&bih=786
I would think pine would not be the best wood to use to achieve that finish though.--Gary--
If you want them to be completely smooth and not wood-grained, I would cover them in a skim coat of auto body putty, sand them smooth and repeat the process, then take them to a body shop and ask if they would shoot them with basecoat/clearcoat black. If they are painting a black car ath the same time, the cost should be minimal. This will give you a durable finish that would be as close to a piano black finish you can get.
You can do that same with cans, but the durability will not be the same.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
MDF -> bondo -> sanding -> primer -> sanding -> primer -> sanding -> primer -> sanding -> paint -> sanding -> paint -> sanding -> paint -> sanding -> clear coat -> sanding -> clear coat -> sanding -> clear coat -> sanding -> clear coat -> buff -> polish
Or something like that... -
No offense, but pine is the about the worst wood to use.
I agree... pine is too soft... you really need a harder wood.... otherwise it will dent easily... -
I'd go with veneer.
Monster AVL-300, HTS-2500 MKII -
Carl
