Piano Gloss like finish
tommyt21
tommyt21 Posts: 685
edited February 2012 in DIY, Mods & Tweaks
I am building some shelfs for my blurays this weekend and would like them to match my tv and entertainment center. What is the best method to achieve a "Piano gloss like" finish? The wood I got is 3/4 X 8 select pine it was $16 a plank. It seems like high quality wood.
ps would like to either do black or a dark walnut
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
  • newrival
    newrival Posts: 2,016
    seem to be some good instructions here:
    http://www.lungster.com/l/speakers/pianofinish.shtml
  • halo71
    halo71 Posts: 4,644
    --Gary--
    nooshinjohn Posts: 26,182
    If you want them to be completely smooth and not wood-grained, I would cover them in a skim coat of auto body putty, sand them smooth and repeat the process, then take them to a body shop and ask if they would shoot them with basecoat/clearcoat black. If they are painting a black car ath the same time, the cost should be minimal. This will give you a durable finish that would be as close to a piano black finish you can get.
    You can do that same with cans, but the durability will not be the same.
  • musky1963
    musky1963 Posts: 275
    No offense, but pine is the about the worst wood to use.
    Jeff
  • zingo
    zingo Posts: 11,258
    MDF -> bondo -> sanding -> primer -> sanding -> primer -> sanding -> primer -> sanding -> paint -> sanding -> paint -> sanding -> paint -> sanding -> clear coat -> sanding -> clear coat -> sanding -> clear coat -> sanding -> clear coat -> buff -> polish
    Or something like that...
  • jon s
    jon s Posts: 905
    musky1963 wrote: »
    I agree... pine is too soft... you really need a harder wood.... otherwise it will dent easily...
  • Syndil
    Syndil Posts: 1,582
    I'd go with veneer.
  • schwarcw
    schwarcw Posts: 7,360
    Syndil wrote: »
    I'd go with veneer.
    I agree, this would be the easiest, fastest way.
    Carl
