yamaha
Willow
Willow Posts: 11,257
edited April 2004 in Electronics
I would like to know how would someone use the vcr out on the receiver when there is already a monitor out as well, the reason I ask is that I dont want to use the front AUX for the PS and my dvd in is used my vsr ni is used and my tv in is used I have the RXV 540 any suggestions on what I can do
Post edited by Willow on
  • Grimster74
    Grimster74 Posts: 2,577
    edited April 2004
    Not to be a ****$ but is there anyway to ask this question again so someone could unerstand it better. I may have a answer for you but I'd like to be clear on the question before answering. Also, is there anyway to list the equipment you are using.
  • Willow
    edited April 2004
    ok well on the back of the yammie RXV540 there's a vcr in which Im using with my sony 4head. just below that connection ( on the rear of the receiver) there is a VCR out with an svideo connection when would this be used as I use the monitor out for all my gear.
    I was wondering how I could hook up the PS1 to the receiver without using the AUX in the front of the receiver.
    IS this better
    RXV540
    marantz dv4200
    sony vcr
    rti4 front (nana plugs with DIY jumpers)
    r10 rears
    csi3 centre
    psw202
    all Acostic research pro series II interconectors
    rca 27" (dunno the model but it works for now)
  • Grimster74
    edited April 2004
    How many inputs do you have on the back of your television?
  • Willow
    edited April 2004
    svideo 1
    rca out 1
    rca in 1
    coax- 1
  • Grimster74
    edited April 2004
    One more question, are you using s-video on your dvd player. I'm trying to come up with a solution for you.
  • Grimster74
    edited April 2004
    Are you using the cable input on the back of the receiver?
  • Willow
    edited April 2004
    yes I am I have all possibilities comp video svideo but right now svid from dvd to receiver and another svid from receiver to tv
  • Grimster74
    edited April 2004
    Okay, here is what I would do "provided" you are "not" using the cable input, I would just run your PS to the input labeled "D-TV/CBL. If you are using all available inputs on the back of your receiver your could always purchase a RF Modulator and run your PS to that beings you don't want to use the front input of your receiver. It's a shame you don't have a component in on the back of your television.
  • Willow
    edited April 2004
    Yes I am using cable inputs
    I know once we move into our new house in 18 days then we can start to look at a new TV (wifes orders). thanks for the help. So I guess its either buy the modulator or wait or use the front inputs
  • Grimster74
    edited April 2004
    Pretty much limited, Yes sir.
  • Willow
    edited April 2004
    thanks for all the input !!
