yamaha
Willow
I would like to know how would someone use the vcr out on the receiver when there is already a monitor out as well, the reason I ask is that I dont want to use the front AUX for the PS and my dvd in is used my vsr ni is used and my tv in is used I have the RXV 540 any suggestions on what I can do
Post edited by Willow on
Not to be a ****$ but is there anyway to ask this question again so someone could unerstand it better. I may have a answer for you but I'd like to be clear on the question before answering. Also, is there anyway to list the equipment you are using.Money Talks, Mine says Goodbye Rob!!!!
ok well on the back of the yammie RXV540 there's a vcr in which Im using with my sony 4head. just below that connection ( on the rear of the receiver) there is a VCR out with an svideo connection when would this be used as I use the monitor out for all my gear.
I was wondering how I could hook up the PS1 to the receiver without using the AUX in the front of the receiver.
IS this better
RXV540
marantz dv4200
sony vcr
rti4 front (nana plugs with DIY jumpers)
r10 rears
csi3 centre
psw202
all Acostic research pro series II interconectors
rca 27" (dunno the model but it works for now) -
How many inputs do you have on the back of your television?Money Talks, Mine says Goodbye Rob!!!!
svideo 1
rca out 1
rca in 1
coax- 1 -
One more question, are you using s-video on your dvd player. I'm trying to come up with a solution for you.Money Talks, Mine says Goodbye Rob!!!!
Are you using the cable input on the back of the receiver?Money Talks, Mine says Goodbye Rob!!!!
yes I am I have all possibilities comp video svideo but right now svid from dvd to receiver and another svid from receiver to tv
Okay, here is what I would do "provided" you are "not" using the cable input, I would just run your PS to the input labeled "D-TV/CBL. If you are using all available inputs on the back of your receiver your could always purchase a RF Modulator and run your PS to that beings you don't want to use the front input of your receiver. It's a shame you don't have a component in on the back of your television.Money Talks, Mine says Goodbye Rob!!!!
Yes I am using cable inputs
I know once we move into our new house in 18 days then we can start to look at a new TV (wifes orders). thanks for the help. So I guess its either buy the modulator or wait or use the front inputs -
Pretty much limited, Yes sir.Money Talks, Mine says Goodbye Rob!!!!
thanks for all the input !!
