Need car/smog advice
dragon1952
dragon1952 Posts: 4,941
edited February 2012 in The Clubhouse
My daughter who lives in California has a '94 Mercedes (gasoline engine) that she had to sit for somewhere between 1 1/2-2 yrs because she lost her job and was on disability and couldn't afford to keep insured/registered. The car was in good shape with a recent excellent rebuild from about 1 1/2-2 yrs prior to that. She had it towed and had all fluids flushed/refilled, new plugs, battery and serpentine belt. It failed smog miserably. She hasn't driven it around much but has had it out on the freeway and says it runs 'great'. So the question is, could the fact that it had to sit for that long be the reason and what would be the first things you would do? It has been suggested that she have the fuel injection system cleaned, new ignition wires for starters. Does she just need to drive the crap out of it and 'blow it out'?
Post edited by dragon1952 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    May I suggest SeaFoam, where you pure half down the brake booster vacuum line and let it stall. Pure the other half in the gas tank, and wait 5-10 mins. Start car and have fun, this will be smokey may I say do this where you can I find some woods. :smile:
    Google it and find some Youtube video on it, it will clean it out.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Drenis
    Drenis Posts: 2,871
    Seaform FTW!
  • Jstas
    Jstas Posts: 15,001
    Yeah, the length of time it sat has a great deal to do with not passing smog.
    Do you know what it failed for? That could help alot in telling you what the issue is.
    But the fuel injection system should be cleaned. The tank should probably be drained too 'cause old gas can cause smog problems as well as sediment getting in to the fuel system. I know everyone is suggesting seafoam but honestly, don't bother with that just yet. Take it to a professional. If you throw a fuel tank additive in there now, everything old that is stuck somewhere is going to get loose and do way more damage and cost way more than just having a pro flush the fuel system and clean out the injectors and such.
    Expert Moron Extraordinaire
  • shawn474
    shawn474 Posts: 3,052
    Jstas wrote: »
    +1; think of the money she saved by not having to drive it for so long. Taking an aolder car like this to a professional to have the proper work done instead of the quick fix is well worth it IMO. It shouldn't be astronomical either. Just the peace of mind of it being done right is worth it.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • Drenis
    Drenis Posts: 2,871
    Jstas wrote: »
    I know some people are suggesting seafoam
    Corrected that.
  • sucks2beme
    sucks2beme Posts: 5,701
    I don't see how wires could cause smog problems unless there was a misfire.
    Whole fuel system need flushing, since modern gas goes bad really fast.
    It's a wonder it ever started up again. The car may come back to near normal with driving,
    but I somehow doubt you'll be that lucky. I vote for a good mechanic to look it over.
    Too many things to look at here, only good home mechanics are going to find them all.
    a 94' may not even be worth the effort.
  • Jstas
    Jstas Posts: 15,001
    Drenis wrote: »
    Corrected that.
  • Drenis
    Drenis Posts: 2,871
    Settle down Jackie Chan. I'll buy you a beer @ Polkfest. :razz:
  • Jstas
    Jstas Posts: 15,001
    Drenis wrote: »
    No, you won't.
  • Drenis
    Drenis Posts: 2,871
    Jstas wrote: »
    No, you won't.
    Why not? Don't drink beer? How about a soda perhaps? I think you folks call them soda's.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    I don't know what the situation is in the town you live in, Dragon, but in this berg you can get a wheelbarrow with a flat tire and broken handle Safety Inspected for an extra $50, and an Emissions Test for an extra $75. And passed.
    Just sayin'.
  • Jstas
    Jstas Posts: 15,001
    Just sayin'.
    Yeah, I know places you can buy an inspection sticker in NJ too. But he honestly has a problem and if it doesn't get it fixed, it's going to turn in to a much bigger and more expensive problem. A clogged injector leans out a cylinder and engine goes BOOM. Then you have a bill that is several thousand instead of several hundred.
  • sucks2beme
    Bottom line- get diagnosed and then fix. Or throw random parts at it and hope for the best.
    Fuel system cleaning DIY style leaves something to be desired. The seafoam through the brake
    vacuum line doesn't do anything for injector cleaning. If you feel frisky, DIY kits
    can be had for about $200. Tank additives aren't likely do get the job done here.
    Sitting for 18 months causes problems that day to day driven cars just don't have.
    Most likely though is it's a combo problem. Injectors, crud on a sensor, EGR valve
    etc.
  • BlueFox
    BlueFox Posts: 15,250
    CA has gotten pretty strict on smog inspection stations. I guess it is possible to fudge the results, but probably isn't worth the risk. Now the test results are transmitted to the DMV as the test is run.
  • dragon1952
    Well she does have a friend that knows someone that can fudge the inspection but I'm with Jstas on this. She has a problem that needs to be addressed or else it can cost in the long run (or even short run). She initially had all the fluid systems drained and flushed including gas/coolant/transmission/oil...I'm assuming brakes. I just gave the OK for the next round which will include the fuel injection system and whatever they didn't do the first time. They were just trying to get it safely running and didn't know about the smog test. Of course I'm paying for all this :^ /
    BTW, she's in S. Cal....I'm on the Oregon coast and we don't have to smog our cars here :^ )
  • Sherardp
    Sherardp Posts: 8,038
    Another vote for Seafoam. I put some in my Mercedes S550 and it's a different animal. Swear to God when it hits 5th gear it sounds like a Lion.
  • disneyjoe7
    dragon1952 wrote: »
    My thinking with this the fuel tank was flushed out and refilled. Right?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dragon1952
    disneyjoe7 wrote: »
    "She initially had all the fluid systems drained and flushed including gas/coolant/transmission/oil"
  • Joe08867
    Joe08867 Posts: 3,919
    Cat is probably screwed up from sitting for 2yrs, It needs to cycle a few times to get any buildup cleared off of it.
    Did she have it flushed after it sat? Did she change the plugs and wires? They all sat for a couple of years and aged. The wires are probably dry rot and the plugs have 2+ year old carbon on them.
    It may just need a good tune up and some running time to clean up.
  • decal
    decal Posts: 3,205
    Just sayin'.
    Surely you are not suggesting that the young lady break the law.
  • AudioGenics
    AudioGenics Posts: 2,567
    dragon1952 wrote: »
    curious ... what emissions test specification did the Benz fail on ?
