USB cable to CD Burner
brgman
brgman Posts: 2,859
edited January 2012 in Electronics
I have a CD burner with the B style USB jack.If i get a standard USB x B style cable will i be able to run audio out of my computer and into the burner?
I’M OFFENDED!!!!
Post edited by brgman on
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2012
    Audio out?
    Main Surround -
  • brgman
    brgman Posts: 2,859
    edited January 2012
    I want audio out of the PC to the CD burner
    I’M OFFENDED!!!!
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited January 2012
    Which CD burner do you have? I doubt it will burn from an audio output, but you should be able to burn audio CD's with a standard usb data connecton.
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Tascam cdrw4u
    I’M OFFENDED!!!!
  • zingo
    zingo Posts: 11,258
    edited January 2012
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Thanks.I didn't get a manual with it or a disk.Also using Windows Vista so i really can't tell if it will work.I'll just find a cheapo cable and try it.If it works i'll buy a quality cable.
    I’M OFFENDED!!!!
