USB cable to CD Burner
brgman
I have a CD burner with the B style USB jack.If i get a standard USB x B style cable will i be able to run audio out of my computer and into the burner?
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
Audio out?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I want audio out of the PC to the CD burnerMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Which CD burner do you have? I doubt it will burn from an audio output, but you should be able to burn audio CD's with a standard usb data connecton.
Tascam cdrw4uMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Here is a link to the USB manual for the unit:
http://pdf.textfiles.com/manuals/ELECTRONICS/AV/CD-RW4U_USB_manual.pdf -
Thanks.I didn't get a manual with it or a disk.Also using Windows Vista so i really can't tell if it will work.I'll just find a cheapo cable and try it.If it works i'll buy a quality cable.
ThanksMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!!
