If you were building a nice SDA IC which cable would you use ?
thsmith
thsmith Posts: 6,082
edited February 2012 in DIY, Mods & Tweaks
I have MIT S3 Shotgun speaker cables and think it would make sense to use an equally nice IC cable ?
Looking for recommendations.
Ideally would like to keep it in the $8 a foot range but don't let that stop you from making a better recommendation.
Currently thinking Kimber 8PR http://www.partsconnexion.com/KIMBER-74602.html
Just to be clear, I am asking about cables to go between my SDA 1Cs speakers to replace the OEM cable.
Post edited by thsmith on
    EndersShadow Posts: 17,704
    edited January 2012
    I am pretty sure you know this already but MIT recommends pairing their IC's with their speaker cables, so you would want a Shotgun S3 or above IC from them.
    No other recommendations as to what would pair well with your speaker cable as your using better wire than I. I will let the other guys chime in.
  • thsmith
    edited January 2012
    Sorry,, what I am looking to build is the IC between my 1Cs.
    I have MIT S3 Shotguns ICs for all my sources.
    heiney9 Posts: 25,432
    edited January 2012
    Canare 4S11.
  • thsmith
    edited January 2012
    Thanks guys.
    Canare 4S11 and AQ T4 are currently top on my list.
    I will be using the Cardas Binding post.
    Toolfan66 Posts: 18,062
    edited January 2012
    You could build a AI-1 dreadnought and use MIT's. :-)
  • thsmith
    edited January 2012
    Been thinking about it but figured for now I would do the easier approach.
    I have no-rez, new gaskets, binding post and IC cable planned for this weekend.
  • thsmith
    I went AQ T4 for the IC between my 1Cs. Excellent improvement over the OEM cable. Wider, taller and deeper soundstage.
    I also tried clearday 2-24g solid silver but I think the gauge was too small as the bass output was about half and the sound stage was no wider than the speakers. I would like to try 6 or 8 - 24g. Paul is a great guy at clearday. He sent me the cable at no cost to try and $45 if I liked it or just return it if not.
    I would like to try anothjer cable that is a step up over the AQ T4 like Kimber Kable TC4.
    Anyone know a good place to get KK 4TC in bulk, say 10'?
    Right now thecableco.com seems to be the best price.
    Any other cable to try? I think Canare 4S11 will be lateral to the AQ T4.
    BTW, I want unterminated as I added Cardas BP for the SDA cable and using GLS locking bananas that screw down then solder for added connectivity.
  • thsmith
    Well, I have a KK 4TC and 8TC coming to try between my 1Cs.
