If you were building a nice SDA IC which cable would you use ?
thsmith
I have MIT S3 Shotgun speaker cables and think it would make sense to use an equally nice IC cable ?
Looking for recommendations.
Ideally would like to keep it in the $8 a foot range but don't let that stop you from making a better recommendation.
Currently thinking Kimber 8PR http://www.partsconnexion.com/KIMBER-74602.html
Just to be clear, I am asking about cables to go between my SDA 1Cs speakers to replace the OEM cable.
I am pretty sure you know this already but MIT recommends pairing their IC's with their speaker cables, so you would want a Shotgun S3 or above IC from them.
No other recommendations as to what would pair well with your speaker cable as your using better wire than I. I will let the other guys chime in."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Sorry,, what I am looking to build is the IC between my 1Cs.
I have MIT S3 Shotguns ICs for all my sources.Speakers: SDA-1C (most all the goodies)
I would use this.
http://www.silversonic.com/docs/products/ProStudio.html
And these.
http://www.soniccraft.com/products/connections/rca/plug/cardas_slvr.htm
Unless you wanted to upgrade the socket too then I would use these
http://www.soniccraft.com/products/connections/banana/cardas_cab.htm
and this
http://www.soniccraft.com/products/connections/bindingpost/cardas_grnd.htmToo much **** to list.... -
Canare 4S11.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
good prices on H9's suggestion...
http://www.ramelectronics.net/audio-video/audio-cables/speaker-cables/custom-canare-4s11-speaker-cable-with-gold-locking-bananas-hs/prodHS.htmlToo much **** to list.... -
Thanks guys.
Canare 4S11 and AQ T4 are currently top on my list.
I will be using the Cardas Binding post.Speakers: SDA-1C (most all the goodies)
Been thinking about it but figured for now I would do the easier approach.
I have no-rez, new gaskets, binding post and IC cable planned for this weekend.Speakers: SDA-1C (most all the goodies)
I went AQ T4 for the IC between my 1Cs. Excellent improvement over the OEM cable. Wider, taller and deeper soundstage.
I also tried clearday 2-24g solid silver but I think the gauge was too small as the bass output was about half and the sound stage was no wider than the speakers. I would like to try 6 or 8 - 24g. Paul is a great guy at clearday. He sent me the cable at no cost to try and $45 if I liked it or just return it if not.
I would like to try anothjer cable that is a step up over the AQ T4 like Kimber Kable TC4.
Anyone know a good place to get KK 4TC in bulk, say 10'?
Right now thecableco.com seems to be the best price.
Any other cable to try? I think Canare 4S11 will be lateral to the AQ T4.
BTW, I want unterminated as I added Cardas BP for the SDA cable and using GLS locking bananas that screw down then solder for added connectivity.Speakers: SDA-1C (most all the goodies)
Well, I have a KK 4TC and 8TC coming to try between my 1Cs.Speakers: SDA-1C (most all the goodies)
