magnet issue?
thejck
thejck Posts: 849
edited January 2012 in Vintage Speakers
On one of my mid drivers drivers.. when I push on it with my fingers spread across the cone from top to bottom and sides I do not hear any scrapping. However if my finger is just on the bottom of the driver and i push I hear a scrapping sound.. Is this a problem?
Post edited by thejck on
    Toolfan66 Posts: 17,995
    edited January 2012
    Your tilling the voice coil just enough to make it rub is my guess..
  • thejck
    thejck Posts: 849
    edited January 2012
    thats what it feels like. i guess i can tell for sure when the coils move the cone rather than my finger. sigh...
    F1nut Posts: 51,700
    edited January 2012
    That's normal, not a problem.
  • skrol
    skrol Posts: 3,437
    edited January 2012
    I have a MW6500 like that if you press the cone slightly unevenly. Musically, sounds fine and plays just as well as the one I replaced it with. I even connected a function generator and ran it through the frequency range and no abnormal sounds were produced.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • thejck
    thejck Posts: 849
    edited January 2012
    thanks guys... appreciate your putting my mind to ease.. for those of us without special equipment.. is there a way to check a driver other than a ohm meter and putting your ear to the speaker?
    F1nut Posts: 51,700
    edited January 2012
    If a driver has a problem, you'll hear it.
  • gdb
    gdb Posts: 6,012
    edited January 2012
    " if my finger is just on the bottom of the driver and i push I hear a scrapping sound."
    Don't do that................. let the electrons do the majority of cone movement.:wink:
  • thejck
    thejck Posts: 849
    edited January 2012
    hehe... I was freaking out cause I had such a hard time pulling the driver off the cab.
