Frequency Sweeps
PolkWannabie
PolkWannabie Posts: 2,763
Doc,
I'd like your ( or others ) comments on the Frequency Sweep graph attached. This is NOT from a sub but from fairly full range towers.
The plot is of adjusted values from 1 meter and from the listening area with 85 db @ 100 hz ( Adjusted ) as the reference.
There several things I find interesting about this plot, not the least of which are that the dip in the 1 Meter graph at 53.1 hz seems to have down shifted in frequency at the listening area and even more curious seems to be the overall flatter response at the listening area then at 1 meter.
Comments ? / Questions ?
Thanks in advance
Post edited by PolkWannabie on
    VR3 Posts: 29,697
    edited April 2004
    Is that the RTi12????
  • PolkWannabie
    edited April 2004
    Yes it is ... On closer examination it's not just the dip that's shifted but virtually the whole curve is shifted and stretched a little.
  • HBombToo
    HBombToo Posts: 5,256
    edited April 2004
    left or right or both?
    HBomb
    ***WAREMTAE***
  • PolkWannabie
    edited April 2004
    The 1 meter readings are one meter out from the left with only that speaker active ... The listening position measurements are for both R & L active.
  • HBombToo
    edited April 2004
    there is your answer bro. Compare apples with apples. do left near field and then far field then repeat for the right. Now that will make for a very interesting analysis.
    HBomb
    ***WAREMTAE***
  • PolkWannabie
    edited April 2004
    Unless I'm missing something, the one meter measurements should not be affected by room acoustics etc. Outside where there are no walls would be even better but inside should be sufficient. Given that the idea behind the one meter measurements really is to test the speakers response as opposed to the rooms effect on the speakers response, I would think that whether one or two speakers are playing at one meter would make virtually no difference.
    No ? ... If not, then could you explain your thinking a little more.
    Personally I suspect the dip-shift (if you'll excuse the expression) is more related to distance from the speaker and wave length but that's just a guess.
  • HBombToo
    edited April 2004
    My thinking is you can't compare 1 speaker near field measurement to a far field measurent with 2 speakers. If you compare the nearfield to far field of just the left that would be more meaningfull. Yo me anyway.
    HBomb
    ***WAREMTAE***
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited April 2004
    That speaker is probably too tall for a 1 meter near field.
    Near field tends to reduce room effects, but it might not completely eliminate them.
    If you can find a spot in the room that is truly quasi anechoic in the near field mic location, consider yourself lucky. Try corner loading the speaker at a 45 degree angle and placing the mic at 2 meters and at mid height and see what happens.
    SVS
  • HBombToo
    edited April 2004
    agreed especially when we are not talking about an omni.
    HBomb
    ***WAREMTAE***
