Brainfarting on connection options?!
obieone
obieone Posts: 5,077
Is it possible to hook up the speaker connections, and LFE on a PSW303? I'd like this sub good for both 2 ch. and HT.:redface:
  • Drenis
    Drenis Posts: 2,871
    edited January 2012
    Short answer, no. Usually they should never be used together what so ever. It's either or.
    Are you having an issue with the way it's currently hooked up? What are you trying to do?
  • obieone
    edited January 2012
    Ok, I couldn't remember. I'm not trying to do anything yet, just was checking on my options.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2012
    what receiver are you using? Are you trying to get the sub working while only using two channel?
