Brainfarting on connection options?!
obieone
Is it possible to hook up the speaker connections, and LFE on a PSW303? I'd like this sub good for both 2 ch. and HT.:redface:
Post edited by obieone on
Short answer, no. Usually they should never be used together what so ever. It's either or.
Are you having an issue with the way it's currently hooked up? What are you trying to do? -
Ok, I couldn't remember. I'm not trying to do anything yet, just was checking on my options.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
what receiver are you using? Are you trying to get the sub working while only using two channel?
