How easy is it to swapout drivers?
I'm sure with a little experimentation, and adequate amounts of libation,
I could find out.
But being that I'm in a room full of scientists, something tells me,
the answer is already known.
I have a cs400i.
thanks,,
-Luc
I could find out.
I have a cs400i.
thanks,,
-Luc
Post edited by trubluluc on
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=12227&highlight=tweeter - Tweeter instructions
The tweeter, to put it back in - just 'snaps' back in place.
The midbasses, just remove the baffle and the midbasses can be removed without trying...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
good to know nothing needed besides a screwdriver and a hammer
-Luc -
Forget the screwdriver, that's too hi-tech, hammer only
Basic, easy task to do Luc.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
-Luc
a good pair of robogrips never hurts either;)
HBomb***WAREMTAE*** -
and a sandwich for break time
Really, you need a allen wrench to get the baffle off and maybe a pair of pliers to pull the connectors. I just replace my left driver of a CS400i. The hard part is figuring which is bad at least in my case. Good luck.
Ray
