How easy is it to swapout drivers?
trubluluc
trubluluc Posts: 2,067
edited April 2004 in Speakers
I'm sure with a little experimentation, and adequate amounts of libation,
I could find out.
But being that I'm in a room full of scientists, something tells me,
the answer is already known.
I have a cs400i.
thanks,,
-Luc
    VR3 Posts: 29,762
    edited April 2004
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=12227&highlight=tweeter - Tweeter instructions
    The tweeter, to put it back in - just 'snaps' back in place.
    The midbasses, just remove the baffle and the midbasses can be removed without trying...
  • trubluluc
    edited April 2004
    good to know nothing needed besides a screwdriver and a hammer ;)
    -Luc
  • dorokusai
    dorokusai Posts: 25,661
    edited April 2004
    Forget the screwdriver, that's too hi-tech, hammer only ;)
    Basic, easy task to do Luc.
  • HBombToo
    HBombToo Posts: 5,256
    edited April 2004
    -Luc
    a good pair of robogrips never hurts either;)
    HBomb
    ***WAREMTAE***
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2004
    and a sandwich for break time :D
  • Marty123
    Marty123 Posts: 32
    edited April 2004
    Really, you need a allen wrench to get the baffle off and maybe a pair of pliers to pull the connectors. I just replace my left driver of a CS400i. The hard part is figuring which is bad at least in my case. Good luck.
    Ray
