Bass Traps and Acoustic Panels - Do they work?
skrol
skrol Posts: 3,452
edited January 2012 in DIY, Mods & Tweaks
All these threads popping up regarding acoustic panels and traps got me thikin'.
Ever wonder if your sound system might benefit from bass traps (not talking fishing here) and/or acoustic panels but didn't want to spend the $$$ to find out. Well here is a try before you buy solution that may help.
Yes, I do enjoy the Red Green Show and I am sure I'll be laughed out of Club Polk for this but here it goes...
Caution, only try this when your spouse or significant other is out of the house...:redface:
Remove the seat cushions from the sofa. These should be fabris an not leather (or vinyl :eek:) as leather will tend to reflect sound.
Place the cushion to the wall adjacent to the speaker at the reflection point. Try moving it to different positions to find the best spot
Also try placing the cushions on the wall behind the speakers.
Yes, I actually tried this and was quite amazed with the difference that it can make. I may be looking into some real acoustic panels and room treatments in the future.
Enjoy
Stan
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
  • thsmith
    thsmith Posts: 6,082
    edited January 2012
    Did you use duck tape to mount the cushions ?
    I love Red Green Show
  • skrol
    skrol Posts: 3,452
    edited January 2012
    "Spare the Duck Tape spoil the job."
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • dkg999
    dkg999 Posts: 5,647
    edited January 2012
    You must use boat seat cushions if you want the true Red Green experience.
    DKG999
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2012
    skrol wrote: »
    Yep.
    As a side note, corners are the place where bass builds up the most and 4 or 5 rolls of Owens Corning Pink insulation stacked in a column in corners will work look bad and take up lots of space, but work very effectively.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • thsmith
    edited January 2012
    skrol wrote: »
    Now, thAT IS FUNNY
    Toolfan66 Posts: 18,077
    edited January 2012
    Do they work??
    Hell yes they do!!!
