Netflix Issue
kiheimer
My Polk soundbar works fine when watching cable shows
When I watch Netflix the audio comes of the back of the TV
but not the soundbar. Is something not hooked up correctly?
Post edited by kiheimer on
How do you have it hooked up?
per instuctions: The supplied cable goes into "Source" at the soundbar then to the TV'S
"Optical Audio Output" -
Sounds like there must be a setting off somewhere. What TV is it?
Monster AVL-300, HTS-2500 MKII -
Samsung LED Smart TV
I have had a simular experience with my set and netflix. After trial and error I actually went back to my TV (vizio) Owners manual to see if I could find anything out. It turns out that my TV will not produce a multichannel sound from the optical output unless it comes from the RF input. Not sure why but that is what the manual said. When I was using the TV speakers (receiver died) with the PS3 the sound that came from Netflix and blu-ray was completely wrong. I would hear some of the music and background noise but no speach. I found that just setting the sound on the PS3 to 2 channel output sovled the problem. I'm not sure if this applies but it might be worth looking into.
Yeah, I will have to get my TV manual out to see if it can be hooked up a different way
My "Activated device" is the TV itself instead of a PS3 or a blueray player. There are two
other ports on the soundbar listed under "source".
