Oppo FW update, ISO format removal. No thanks...
Glowrdr
I'm thinking if it ain't broke, don't fix it...
3.Per the request from the studios, the ISO file playback function has been removed in this firmware version. The previous firmware had the ability to play ISO files, but it was an undocumented function and was never officially announced or supported. Future firmware version will no longer support ISO playback.
65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa"
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Post edited by Glowrdr on
I'll spread the word, thanks."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
ISO is just a disk image format. So you can just burn it to CD/DVD.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
LOL. Exactly. It's like a zipped file, which you just dump onto a disc, or there are tons of free software titles that will convert it for you to any other video format.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
That is true, but thought it heeded a warning. I myself actually keep things in an ISO format. I used to keep discs around, but founf it was easier just burn the ISO if I needed to have the physical inventory. Now I barely even do that, I just mount the image itself if it's software.
This is potentially like them saying "eh - we aren't supporting FLAC anymore. Just convert it to something else, no biggie"65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Can you post a link to the original article?
Thanks! -
http://www.oppodigital.com/blu-ray-bdp-93/bdp9x-firmware-64-0119B.aspx
I read through the 83 update, and it appears the 83's must not support DLNA? I'm not seeing that same excerpt.
This is a beta release, but it will eventually be released as a standard upgrade (don't want anyone thinking I'm pulling the wool over their eyes about a beta release)65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Thank you! I don't have the Oppo but a friend does...just wanted to make sure he was aware of this.
I am one of those who recently purchased an Oppo player. I usually play back Blu-Ray movies on my player.
Thanks for the heads up!!!Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart.
