Placement of RTIA9 on Hardwood
photocrazy
How do you place your RTIA9s on hardwood? do you use any isolation pads ?
Post edited by photocrazy on
Spikes with floor discs.Political Correctness'.........defined
President of Club Polk -
Mine came with rubber pads on the bottom of the feet. I used the included spikes since I'm on carpet.
Mine also came with paded feet, therefore they sit on the feel they came with.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
Spikes are always the better choice.Political Correctness'.........defined
Where is a good place to get Floor Discs?
A better question is what should one look for in floor discs. Material? Brass seems most common, but a couple of places have aluminum and titanium. What about some kind of pad to go between the disc and the floor, should you use them? Are they just to protect the floor from getting scratched?
I have some floor disc..
PM me your address and I will drop 8 in the mail for whoever needs them... (meaning the person in this thread, I dont have THAT many)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Three 20 amp circuits. -
Yeah.. mine are free - that makes them better
Although those are very nice...
Has anyone ever put like felt or anything under their floor savers? Does this defeat the purpose?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
