Adcom gfa 555 question
JTodd
Hey guys! New to home theater an in the market for an amp. I found an Adcom gfa 555 for sale for $195.00! This is a great deal.....right? It is in mint condition and has just been checked out by an audio tech. I think this is a winner but would love more knowledgeable peoples input. Thanks in advance!!
Post edited by JTodd on
That is a horrible deal. You should tell me where it is and I will go tell them!65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Good amp, great price. It will get you addicted to separates. It is not the end all be all, but a great way to get started. What would you be using as a preamp for this?
Nice deal!!! I am not sure but I think that Adcom was design by Nelson pass.Make it simple...Make it better!
Agreed terrible deal he should be paying at least $300.That is a horrible deal.
Yes indeed.I think that Adcom was design by Nelson pass. -
I am going to use a Harman Kardon avr 247 with it. Will that work or will I need an actual pre amp?
That will work just fine. It's one of those things that if you know for a fact you are buying equipment, and that involves an amp - get a pre. It's considered a waste to buy an AVR just to bypass the amps - but there is nothing wrong with it. Plus, you will be using the surround channels so it all works out.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Cool! Thanks for the help guys! Do you guys know of any good site for "how to properly hook up an amp"? Like I said i'm a noob and dont want to screw anything up.
Use this site and your manual for your info.
Get some decent interconnects, from signal, blue jeans, or whatever your heart and budget desires2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Pretty straight forward. Use the LF/LR outputs into the amp. Then switch your speaker wires from the AVR to the amp itself. I'm not sure if any settings need to be changed with the receiver settings though. This is where the manual will come in handy.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
great deal if your sure all is wellw/it . Mine as I said before has the formal rackmount face that I got at Audio CLssics for $300.Absolutely quiet and go for mid to better ICs and a pre and you'll be on your way to 2-chl ville.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
