Room EQ software/hardware
gmcman
gmcman Posts: 1,839
edited January 2012 in DIY, Mods & Tweaks
I'm looking for a somewhat simple program to use to measure my room acoustics. I see that PE has a mic for this and was curious as to what software is compatible with this. I know there are some free programs that work well but i'm wondring what others have had success with.
Post edited by gmcman on
  • thsmith
    thsmith Posts: 6,082
    edited January 2012
    Room eq wizard at hometheatershack.com. It is a lot easier than it looks. Several here including myself use, although for me mostly for subs but it can do more. Get your read on and ask questions. Good bunch or used to be over there.
  • thejck
    thejck Posts: 849
    edited January 2012
    i keep trying to read about it on there and get stuck. What kind of hardware do you need to get started?
  • thsmith
    edited January 2012
