Room EQ software/hardware
gmcman
I'm looking for a somewhat simple program to use to measure my room acoustics. I see that PE has a mic for this and was curious as to what software is compatible with this. I know there are some free programs that work well but i'm wondring what others have had success with.
Room eq wizard at hometheatershack.com. It is a lot easier than it looks. Several here including myself use, although for me mostly for subs but it can do more. Get your read on and ask questions. Good bunch or used to be over there.Speakers: SDA-1C (most all the goodies)
i keep trying to read about it on there and get stuck. What kind of hardware do you need to get started?
Everything here came from hts, http://www.polkaudio.com/forums/showthread.php?123687-REW-Room-EQ-WizardSpeakers: SDA-1C (most all the goodies)
