Deleting audio files correctly
brgman
brgman Posts: 2,859
edited January 2012 in Electronics
I have started using JRiver exclusively but still have Winamp and itunes in my computer.
If i delete the Winamp completely will this wipe out the files also or will they still be safe in JRiver?
I have so many duplicates that come up in my Squeezebox and want to eliminate this crap but i am in over my head i think.
My computer is for google searches,email,Polk Forum and ****.Anything beyond this and i get confused.:eek:
I’M OFFENDED!!!!
Post edited by brgman on
  • ratster
    ratster Posts: 324
    edited January 2012
    brgman wrote: »
    They do more :question:
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • Drenis
    Drenis Posts: 2,871
    edited January 2012
    You'll be fine to uninstall Winamp. Your files are saved in a folder which Winamp will see as a library or directory where it plays your files from their saved location.
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    edited January 2012
    Windows media player likes to take all of my Itunes music and duplicate it as well. I hate that, it's annoying and slows down my computer. it took me forever to figure out how to make it stop, I can't even remember how I did it. I do not use Winamp anymore, all I used it for was decompressing illegally downloaded music. idk what that other thing is.
    in Winamp you should be able to figure out how to make it to where it doesn't copy files into it's library, either that or doesn't duplicate them.
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2012
    A magnum 45 to the forehead followed by bose being chiseled into the tombstone and dont forget to ask the mortician to put an emotiva T shirt on the deceased
  • Mr. Sharpe
    edited January 2012
    Minus the Bose
    oh yeah, I deleted winamp a long time ago so I don't know how many different things they've added and done to it since uh.. idk when that was. good luck:)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • brgman
    brgman Posts: 2,859
    edited January 2012
    we'll see what happens
    i still need a way to keep itunes out of JRiver also
    i need to look at the settings and see if they have a way to do it
    thanks for the input
    I’M OFFENDED!!!!
  • Mr. Sharpe
    edited January 2012
    I hope you get it working the way you want it.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • timalan
    timalan Posts: 106
    edited January 2012
    You're safe deleting winamp. Just be careful if you decide to nuke iTunes... it SHOULDN'T delete any of your actual music, but depending on how you have the files stored, I'd use caution.
    Realistically, all of your music files should be stored independently of any of the music playing software on your system. As for eliminating duplicates, that can be a PITA. I'm still in the midst of a several-year project to clean up all the music files on my system, eliminate duplicates, clean up ID3 tag data, etc... anymore though, I've gotten lazy and it's easier to either pop a single CD into the player or just use Pandora to pull up background music. Someday though....
    5.1 theater - Pioneer SC-07, Mirage OMD-CC center, 4 x Mirage Omnisats, Boston Acoustics VPS-210 sub
    2.1 living room - NAD 7400 integrated, 2 x Platinum Audio Duos, MIT Terminator4 cables
    2.1 bedroom- Arcam Solo, 2 x Mirage OMD-5's
    FOR SALE - Genesis Servo-10 sub, Genesis Servo-12 amp; Martin Logan Dynamo sub; Mirage MM-6 sub; Harman Kardon DPR-1001 7.1 receiver
  • brgman
    brgman Posts: 2,859
    edited January 2012
    It is a pain in the arse.
    I am entertaining getting a somewhat inexpensive computer just for music files and run the squeezebox from that and ditch all teh files on this one.
    I’M OFFENDED!!!!
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited January 2012
    ^^ I'm with ya on that. I LOOOOOOAAAATHE iTunes, Windows Media Player, and any other software that wants to manage my library for me. Seriously, give VortexBox a try - www.vortexbox.org
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Well ain't that an interesting piece.I did a little reading but will do more.May be just what i need.Thanks!
    I’M OFFENDED!!!!
  • Mr. Sharpe
    edited January 2012
    Like was said, I would back up all your music before deleting anything.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • mdaudioguy
    edited January 2012
    brgman wrote: »
    Just download the ISO file, burn it to a CD, and install it on any old (or new) PC. It's easier if you install it with a monitor attached, but once it's up and running, you can disconnect the monitor and do everything remotely. So easy, it's ridiculous. I built an affordable little, dedicated music server with a low-power CPU (Intel Atom) that runs 24/7, but only uses something like 13W max. It resides on my network, so it doesn't necessarily have to be anywhere near my other computers or my music rigs. Oh yeah, Squeezebox Server is part of the installation - feeds all of my Squeezebox players. Read all the documentation - especially the FAQs. They've also got a nice little forum there, too. Yes, I'm a fan!
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Looks slick.Computer compatibility any issue?
    I have an old desktop unit but it is XP
    I’M OFFENDED!!!!
  • mdaudioguy
    edited January 2012
    brgman wrote: »
    It replaces your current OS, so if there's anything on there you want to save, copy it to somewhere else first.
  • strider
    strider Posts: 2,568
    edited January 2012
    Zingo's got a computer set up with Vortexbox for sale in the FM currently. Asking $100, IIRC. Ad states he was interested in a local deal, but maybe you can work something out with him.
    Wristwatch--->Crisco
    tonyb Posts: 33,065
    edited January 2012
    I'd be carefull deleting any of windows programs. Seems they purposely made most to run in some way with others and deleting one program can cause others not to work properly. Been there done that.
  • mdaudioguy
    edited January 2012
    tonyb wrote: »
    I don't think deleting any Windows programs was on the table. He was talking about deleting Winamp, a third-party media player. Hopefully, he's moving forward with an even better solution. :wink:
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Yep.Winamp is gone.Now i am working on the duplicates and trying to clean up multiple files and locations of files.
    A daunting task indeed.I have been ripping,downloading,adding and deleting for about 4 years on this puter and it is a NIGHTMARE!
    Until i got the squeeezebox it didnt matter but now it needs help.
    LOTS of help.
    I’M OFFENDED!!!!
  • mdaudioguy
    edited January 2012
    brgman wrote: »
    LOTS of help.
    Been there, done that! Got some great advice in these threads:
    http://www.polkaudio.com/forums/showthread.php?115652-Consistent-tagging-of-digital-music-is-impossible!
    http://www.polkaudio.com/forums/showthread.php?116943-Digital-music-management
