Need more power!
Hey guys. I have recently purchased a pair of Rti 8's and I am running them off a HK AVR 247. 50W per channel. I would like more power. I am relatively new to all this and have no experience with amps. What would be some cost effective ways to deliver more watts to these speakers? Change AVR's or go with an amp? Thank in advance for the help!!
Post edited by JTodd on
If your HK has pre outs do this
http://www.polkaudio.com/forums/showthread.php?128335-Adcom-5503-(3-channel-power-amp)Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Clear Day dbl.shotgun
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun -
Well i was looking at your HK and it does have preouts.Are you just wanting to power up your 8's or more speakers?Budget etc.Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player -
Welcome to the forum. Like ratster says, if your avr has pre-outs, you can add a power amp. If it doesn't, then you may consider upgrading your avr to something larger with more power and available pre-outs.
If you have that AVR you have the ability to add an amp using the available preouts.
There are lots of nice amps to be had on the used market by B&K, Rotel, Adcom, Parasound and many others.
What are you looking to spend. -
I will probably just power the rti8s. I am going to order an csi5 center but I think 50 watts should be good with that...right? I would like to keep it under $500 but all the amps I have looked at are quite expensive. Dumb question.... Is there a difference between preamps and power amps? Thanks guys!!
I sent an email seeing if it was still avaliable. Any other options at or below that price point?
In the used market, YES.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I want this one so bad I can hardly stand it, but I just can't spring for it right now.
http://www.polkaudio.com/forums/showthread.php?128398-B-amp-K-reference-200.2-%28375x2-RMS%29Things work out best for those who make the best of the way things work out.-John Wooden -
The one that Dskip linked would be just right.Also, since you're going to order a CSi5, that 3channel would be perfect.Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
