Distorted sound
bolelet1
Hi,
Until recently, I've noticed that the right channel, both the front and back of my 5.1 AV Yamaha receiver RXV1400 started making distorted sounds. I have switched the speaker connectors and it does the same thing to the left channel. Any idea what's wrong with my yammie or is it something else. Please help. Thanks. Bolelet1
Post edited by bolelet1 on
It's probably your receiver, and it means it's time for a new one.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
That was cold, true but cold. But I think he is correct.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Possibly, but "distortion" is a pretty generic term and can mean different things...
Are we talking "garbled" or "raspy" or "crackling" or...?More later,
Tour...
Vox Copuli
Also, what speakers are you using? Have you tried a known-good set?polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter
