Distorted sound
Hi,
Until recently, I've noticed that the right channel, both the front and back of my 5.1 AV Yamaha receiver RXV1400 started making distorted sounds. I have switched the speaker connectors and it does the same thing to the left channel. Any idea what's wrong with my yammie or is it something else. Please help. Thanks. Bolelet1
  • quadzilla
    edited January 2012
    It's probably your receiver, and it means it's time for a new one.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • soundfreak1
    edited January 2012
    That was cold, true but cold. But I think he is correct.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Tour2ma
    edited January 2012
    Possibly, but "distortion" is a pretty generic term and can mean different things...
    Are we talking "garbled" or "raspy" or "crackling" or...?
    More later,
    Tour...
    Vox Copuli
  • Bobsama
    edited January 2012
    Also, what speakers are you using? Have you tried a known-good set?
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
