PSW111 vs. PSW125 and TSi100 vs. TSi200
ksilva09
ksilva09 Posts: 1
edited January 2012 in Speakers
Hi there,
Just bought a pair of TSi400's with a CS20 and it included a PSW111. Still haven't hooked them up yet, but my Denon receiver is coming in the mail. I can return the PSW111 and upgrade to the PSW125 for $50. I like the size of the PSW111, but it would be possible to put in the bigger the sub. I was just wondering if it's worth it? Also, I still haven't decided on the TSi100 vs. the TSi200s for the surrounds. Does the price difference justify the differences between them? I was also a little worried that the TSi200s would look a little bulky mounted on the wall. Any suggestions are welcomed.
Post edited by ksilva09 on
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited January 2012
    If your focus is more on music, keep the 111, but if you're more into Home Theater then 125.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
    edited January 2012
    Welcome to Club Polk!
    L91 has your back. But if you're into HT more. Get the 125 or better yet an older PSW505 and a couple of TSI-100s. Once you have a decent sub you can relax about the surrounds and let the SUB do your work!
    Enjoy!
    cnh
