PSW111 vs. PSW125 and TSi100 vs. TSi200
Hi there,
Just bought a pair of TSi400's with a CS20 and it included a PSW111. Still haven't hooked them up yet, but my Denon receiver is coming in the mail. I can return the PSW111 and upgrade to the PSW125 for $50. I like the size of the PSW111, but it would be possible to put in the bigger the sub. I was just wondering if it's worth it? Also, I still haven't decided on the TSi100 vs. the TSi200s for the surrounds. Does the price difference justify the differences between them? I was also a little worried that the TSi200s would look a little bulky mounted on the wall. Any suggestions are welcomed.
Post edited by ksilva09 on
If your focus is more on music, keep the 111, but if you're more into Home Theater then 125.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
Welcome to Club Polk!
L91 has your back. But if you're into HT more. Get the 125 or better yet an older PSW505 and a couple of TSI-100s. Once you have a decent sub you can relax about the surrounds and let the SUB do your work!
Enjoy!
