LSi-15 OWNERS...Average amp size
ematthews
ematthews Posts: 27
edited January 2012 in 2 Channel Audio
Trying to get an idea of what LSi-15 owners are using to power their speakers. Amp size for good sound
I just ordered an Emotiva XPA-2. 500 watts per channel at 4 ohms. I know I can go larger like Mono's, but I can't afford it right now..
Post edited by ematthews on
    EndersShadow Posts: 17,687
    edited December 2011
    ematthews wrote: »
    Well I am using a 125x5 watt Carver amp that does about 200ish per channel @ 4 ohm on my LSi 15's.
    Personally though I would look used if your comfortable with buying used. You might be able to save some money and get an amp thats just as good.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    ematthews wrote: »
    What exactly are you asking? You already ordered an amp with a ton of power, and I'm sure you know that. So what are you trying to find out here?
    Everybody is powering their speakers differently. In most cases, the more power the better. That amp will be fine. I've owned the XPA-2 and it really does bring the house down. It's more than you'll ever need your speakers.
  • ddward
    ddward Posts: 4
    I use a sunfire cinema grand. 400 watts at 4 ohms per channel x5. Sounds FANTASTIC!
    Sunfire cinema grand amp, Marantz sr6500 pre/pro, Polk lsi15 mains, Polk lsic center, Polk lsi7 rears,
    Def tech sub. Blue Jeans interconnects.
  • ematthews
    ematthews Posts: 27
    I was curious...That's it..
  • acmf74
    acmf74 Posts: 937
    Adcom 5802 450 @ 4ohms
    Now looking for a mint GFP-750 preamp to compliment it.
  • HHStuart
    HHStuart Posts: 263
    Outlaw 7125 - 190 amps @ 4 ohms
    Seems adequate but I sometimes wonder if I should get something even more powerful.
    Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
    Subwoofer - Epik Legend
    Receiver (as Preamp) - Sony STR-DA3400 ES
    Amplifier - Outlaw 7125
    Television - 58" Samsung Plasma PN58B860
    Blu Ray - OPPO BDP 83
    pitdogg2 Posts: 26,924
    HHStuart wrote: »
    I wouldn't think you'd need more than 190AMPS talk about smoking voice coils:eek::eek::biggrin:
  • niente
    niente Posts: 68
    Parasound 5250
    Onkyo TX-SR804 receiver
    Parasound 5250
    LSI 15's
    LSI C
    LSI FX's
    PSW1000 Sub
    OPPO 93
    Sony CDP-C315 CD
    Monster AC line cond
    Audioquest, Blue Jeans & Monster wires/connects
    40" Sony Bravia XBR6
  • ematthews
    ematthews Posts: 27
    edited January 2012
    You need a lot more to get the full use of these speakers. I will be using 500x2 in about two months. Right now I am using 185x2
    and it works the amp..
  • grimmace19
    grimmace19 Posts: 1,429
    edited January 2012
    Ive got the Adcom gfa-7500 that says 225 @ 4ohms x 5 and love it. Wouldn't mind a dedicated 2 channel amp for the front though.
  • iskandam
    iskandam Posts: 704
    edited January 2012
    You should be good to go. I used to drive mine with the MPS-1 then XPA-5. I found that the MPS-1 is a much better match for the LSis than the XPA-5. Incredible detail, clarity, more space between instruments, and killer bass to boot.
  • michael1947
    michael1947 Posts: 775
    edited January 2012
    very good information, thanks.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
    edited January 2012
    ematthews wrote: »
    read a little closer I was gigging him because he mixed AMPS for watts ....190AMPS is MUCH more that your 500watts jeesh:rolleyes:
  • LuSh
    LuSh Posts: 887
    edited January 2012
    I used an 80 watt Simaudio integrated amplifier...I find the power numbers recommended are rather numerous. Any dedicated amplifier will drive LSis fine with a high quality per-amplifier section.
  • ddsski
    ddsski Posts: 50
    edited January 2012
    FYI my Mac MC352 350/wt/ch has a hx of terminating the crossovers on the LSi15's 500wt/ch if you use it all will probably fry the electricals!!!:cry:
    The MAINE System
    Marantz AV7005
    2 Carver M200t's biamped, Adcom GFA 7000
    Pioneer DV-46A, Lightspeed
    Polk LSi 15's, PMC DB1+C, Polk LSi7, Sunfire True Sub II
    Samsung HP-T1254 42in Plasma
    Kubala Sosna Center wiring, DAO Kubala Sosna , Apature & Monster HDMI's
    The CT System
    Marantz AV7005
    MacIntosh MC352, Marantz MM7705w/Sig. upgrade
    Polk LSi15's, Golden Ear Technologies Sat 50's & 50C
    Kubala Sosna Speaker wire, Audioquest interconnects and assorted other goodies
    tonyb Posts: 33,065
    edited January 2012
    We all going to stand in a corner now and wip it out....amps that is,:cheesygrin:....to see who's is bigger ?
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    tonyb wrote: »
    Let me know when you all are done haha.
    Too much **** to list....
  • niente
    niente Posts: 68
    edited January 2012
    As I think Milton Berle said--i'll only pull out enough to win!
    Parasound 5250
    LSI 15's
    LSI C
    LSI FX's
    PSW1000 Sub
    OPPO 93
    Sony CDP-C315 CD
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    niente wrote: »
    Good one! Dad always said "If you contend you must overcome...If you do not contend you must simply endure"
    Love it!
  • BlueFox
    BlueFox Posts: 15,251
    edited January 2012
    tonyb wrote: »
    As The Nuge says; "When in doubt, whip it out.."
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2012
    it's about quality, not quantity, of watts, fellas. Ever heard of the motion in the ocean? I t goes a long way, especially in audio.
  • falconcry72
    edited January 2012
    ematthews wrote: »
    Even if he was talking about watts, not amps, you still don't have the right idea. There are a lot of crappy, high wattage amps out there that won't sound nearly as good on those speakers as any number of low-wattage, high-quality amps.
  • zingo
    zingo Posts: 11,258
    edited January 2012
    I really like ICEpower amps with the LSi series. I built a 250wpc ICEpower amp for my father-in-laws LSi15s and they sound great.
    tonyb Posts: 33,065
    edited January 2012
    I was gonna whip mine out, but I'm wearing button flys....who has time for all those buttons anyway ?
    Even the wife, after 2 buttons says " 'EFF IT, I give up, you do it."
  • chargerman426
    chargerman426 Posts: 419
    edited January 2012
    I use a pair of 70 watt mono block tube amps during the winter and ether a 40 watt tube integrated amp or a 20 watt integrated. And unless I'm trying to blow the house down the 20 watt el84 based amp sound the best.
    If life had more tubes it would be a lot smoother.
    F1nut Posts: 51,668
    edited January 2012
    Fell on deaf ears, but at least you tried.
    tonyb Posts: 33,065
    edited January 2012
    Not to those paying attention Jess.
  • falconcry72
    edited January 2012
    I think some people have their answers before they ask their questions.
  • mole'
    mole' Posts: 3,160
    edited January 2012
    Cinenova grade 5 for my LSi's
    had a XPA-3 before and it powered them just fine. but they do love the high power
    mole'
  • McLoki
    McLoki Posts: 5,231
    edited January 2012
    you won't get a good average amp size by looking at club polk owners... Most of us (including me) are way above average and well compensated for - as in - we must be compensating for something......
