Laptop Audio Output
I decided o go with the HRT music streamer II. Its the cheaper of the expensive ones. Also, it works better with Mac than most of the other ones. I'm sure it will be more than enough for my ears though!
Congrats, it will be a huge improvement over the headphone jack.:biggrin:
Make sure you use a media player that is compatible with ASIO or WASAPI to really get the most out of it.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
i have this issue also with laptop hum. i wonder if it is a grounding issue as sometimes i can touch the laptop and it goes away.
could just be a crappy headphone jack tho. use headphone jack to y adapter to int. amp.
i am looking into trying the W1 (?) from audioengine. a wireless usb transmitter/receiver to get rid of the longf audio cable.
has anyone used this solution? it costs $99 at audioengine.com.
thanks in advance.
