TV on top of Center channel???????????
bobsauto49
bobsauto49 Posts: 973
edited January 2012 in Speakers
Can i put the 55" Samsung which weighs about 45 lbs on top of my center channel,which is placed on my entainment center? Any thoughts apprieciated.
"Everything I ever did in my life worthwhile I caught hell for"
Post edited by bobsauto49 on
  • Geoff4rfc
    Geoff4rfc Posts: 2,956
    edited January 2012
    It might be best to build or incorporate a shelf for your TV to sit on while the center speaker is underneath. Myself and a few others have built their own. Please excuse this crude effort;
    This was my first set up and I have long since improved the aesthetics of things.
  • Gadabout
    Gadabout Posts: 1,072
    edited January 2012
    You could, I suppose but that is something I wouldn't even consider. Why vibrate the TV even if a little and center channels aren't designed for load bearing.
    Have you thought about buying or building a riser? (geo beat me to it ;-) Without more details that seems like the most sensible solution.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • Syndil
    Syndil Posts: 1,582
    edited January 2012
    Could always float the TV above the speaker and mount it to the wall. Monoprice has durable mounts at reasonable prices.
  • rengnath
    rengnath Posts: 118
    edited January 2012
    I have my 32" Samsung on my center temporarily. I originally had the center in my stand, but I upgraded to the cs400i and the top of the stand is the only spot it would fit. The HT system will soon be going in a rec room though, with a much larger tv and stand that the center will fit in.
    AVR - Yamaha Aventage RX-A800
    Amps - B&K Components ST2140 (for mains) and Parasound HCA-1000A (bi-amping center)
    Mains - RT1000i Towers
    Center - CS400i
    Sub - BIC Acoustech PL200
    My neighbors listen to very good music, whether they like it or not :cheesygrin:
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    Syndil wrote: »
    The best advice by far.
  • maggiefan
    maggiefan Posts: 223
    edited January 2012
    Here's what I did. Made with 1"X10" ash. Very sturdy and doesn't look too bad. Think I spent less than $40 on it.
    Larry
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited January 2012
    ^ very nice maggie- that was an elegant solution
  • DaveHCYJ
    DaveHCYJ Posts: 89
    edited January 2012
    The speaker stands people have suggested are a good idea, but you have to be careful if your speaker has rear bass ports. It can make the sound boomy if they don't have enough space. You also need to make sure the front of the speaker isn't recessed in the stand or you get the effect like its in a cave. I ran into that.
  • bobsauto49
    edited January 2012
    Thanx for all the input guys! I caved and bought a full range wall mount! Was just trying to save a couple hundy,if u know what i mean! Now,,,,,,, What Else Can I Buy!!:frown:
  • Geoff4rfc
    edited January 2012
    maggiefan wrote: »
    Not bad my friend, very handy work, my wife is a huge fan of "L" brackets....not. A man can never have too many "L" brackets.
    bobsauto49 wrote: »
    NEVER EVER ask that question here!!!!!
  • maggiefan
    edited January 2012
    Thanks, really didn't want to use them. Didn't know how else to do that without screws showing on the top. I covered the back but left the center compartment partially open for the center channel.
    Larry
