TV on top of Center channel???????????
bobsauto49
Can i put the 55" Samsung which weighs about 45 lbs on top of my center channel,which is placed on my entainment center? Any thoughts apprieciated.
"Everything I ever did in my life worthwhile I caught hell for"
Post edited by bobsauto49 on
It might be best to build or incorporate a shelf for your TV to sit on while the center speaker is underneath. Myself and a few others have built their own. Please excuse this crude effort;
This was my first set up and I have long since improved the aesthetics of things.Set up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
You could, I suppose but that is something I wouldn't even consider. Why vibrate the TV even if a little and center channels aren't designed for load bearing.
Have you thought about buying or building a riser? (geo beat me to it ;-) Without more details that seems like the most sensible solution.
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
Could always float the TV above the speaker and mount it to the wall. Monoprice has durable mounts at reasonable prices.
Monster AVL-300, HTS-2500 MKII -
I have my 32" Samsung on my center temporarily. I originally had the center in my stand, but I upgraded to the cs400i and the top of the stand is the only spot it would fit. The HT system will soon be going in a rec room though, with a much larger tv and stand that the center will fit in.AVR - Yamaha Aventage RX-A800
Amps - B&K Components ST2140 (for mains) and Parasound HCA-1000A (bi-amping center)
Mains - RT1000i Towers
Center - CS400i
Sub - BIC Acoustech PL200
My neighbors listen to very good music, whether they like it or not :cheesygrin: -
The best advice by far. -
Here's what I did. Made with 1"X10" ash. Very sturdy and doesn't look too bad. Think I spent less than $40 on it.Larry -
^ very nice maggie- that was an elegant solution2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
The speaker stands people have suggested are a good idea, but you have to be careful if your speaker has rear bass ports. It can make the sound boomy if they don't have enough space. You also need to make sure the front of the speaker isn't recessed in the stand or you get the effect like its in a cave. I ran into that.
Thanx for all the input guys! I caved and bought a full range wall mount! Was just trying to save a couple hundy,if u know what i mean! Now,,,,,,, What Else Can I Buy!!:frown:"Everything I ever did in my life worthwhile I caught hell for"
Not bad my friend, very handy work, my wife is a huge fan of "L" brackets....not. A man can never have too many "L" brackets.bobsauto49 wrote: »Now,,,,,,, What Else Can I Buy!!:frown:
NEVER EVER ask that question here!!!!!Set up: 11.2 HT + 2ch
Thanks, really didn't want to use them. Didn't know how else to do that without screws showing on the top. I covered the back but left the center compartment partially open for the center channel.Larry
