How to do the JB weld mod and not make a mess?
muncybob
muncybob Posts: 3,235
edited January 2012 in Vintage Speakers
How have you guys done this without making a mess? I've used a pack of JB and still have 1 more speaker to do on the 2B's! Using popsicle sticks to spread it but it's still getting everywhere I don't want it to be.
Yep, my name really is Bob.
Post edited by muncybob on
    Toolfan66 Posts: 17,995
    edited January 2012
    Are you going all the way around the magnet? Both sides? If so its not necessary. You should be able to do both speakers and still have some left over..
  • brgman
    brgman Posts: 2,859
    edited January 2012
    That's why i use the Loctite stick.roll it in your fingers to mix it.it's like gum,or boogers:eek:
    little mess at all
    I’M OFFENDED!!!!
  • evhudsons
    evhudsons Posts: 1,175
    edited January 2012
    I made a mess and loved every bit of it. Just get it on enough to adhere four sides, should be fine. Good thing that side of the driver is hidden inside the speaker
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    :cheesygrin:maybe a couple of pics would be fun to look at...er would help others give suggestions
    dont get that stuff on your camera.
    Too much **** to list....
  • evhudsons
    edited January 2012
    I put out just a little bit at a time because it's starts to cure pretty fast. At least faster than I was applying.
    I did a bit of DIY last night and now am enjoying my work. Fixed a bad phono RCA plug, so now records in stereo with no hum, fixed an RCA jack pin on the adcom, and now that's a solid connection. I got a replacement driver for one I messed up by not properly cutting the rubber surround from screw holes. I'm jb welding tomorrow the new driver. I think it's cool despite the mess. I used an old broken screwdriver instead of a stick.
  • evhudsons
    edited January 2012
  • drumminman
    drumminman Posts: 3,396
    edited January 2012
    muncybob wrote: »
    Just got to be a little careful. And use lots of paper towels to clean the surplus, they're your friend :cheesygrin:
    I did mine like those in the thread EV linked - top and bottom lf magnets/plates.
    F1nut Posts: 51,699
    edited January 2012
    brgman wrote: »
    little mess at all
    Damn good idea!
  • muncybob
    edited January 2012
    I have one speaker left to do, just might give Loctite a try.
  • brgman
    brgman Posts: 2,859
    edited January 2012
    Loctite part number is 98853 i believe.
    I’M OFFENDED!!!!
  • muncybob
    edited January 2012
    Lowes had it along side a similar product made by JB...looks a lot easier to use...thanx!
  • gdb
    gdb Posts: 6,012
    edited January 2012
    I use an artist's palette knife to both mix & apply the JB Weld, works very well with excellent control. I use the regular and not the quick setting stuff. And LOTS of paper towels and acetone!:wink:
  • muncybob
    edited January 2012
    Now I realize perhaps I should have asked this question before starting the JB Weld application...so with that in mind, just received a 4 sq ft sheet of Dynamat. What's the best way to apply this? I've never used this stuff before.....
    F1nut Posts: 51,699
    edited January 2012
    You got Dynamat Extreme, right? Cut it with scissors or a razor knife, peel off the backing and press it in place. You don't need to cover every square inch, a little goes a long way.
  • muncybob
    edited January 2012
    I was thinking to cut it to a general size, press in place and use a knife to trim excess? I think it's Extreme, came in a 2' X 2' sheet.
  • drumminman
    edited January 2012
    muncybob wrote: »
    You just want to cover the "spokes" of the speaker baskets. I also put pieces on the round part between the spokes perpindicular to the flange that contacts the front baffle; none on the flange, though.
    Cut to fit - doesn't have to be exact.
    F1nut Posts: 51,699
    edited January 2012
    The Extreme has a foil layer, regular doesn't. You want the Extreme as the regular doesn't stick all that well. As Fred stated, cut to fit. You're looking at something like a 1" x 2" strip for every spoke.
  • muncybob
    edited January 2012
    got it.......
