Powering the MM12
Systems
I bought the MM12 self enclosed momo unit.. Am thinking about the MTX Thunder 801d which is rated at 400Wx1 RMS.. is that too much? Anyone running it already?
Testing
Testing
Testing
Testing
Testing
it can handle more... 500 is rated, many people here push it with up to 650.It's not good, very fundamentally simply not good. - geolemon
that amp is too small for that sub... if you're gonna stick with one momo 104 sub, then go with an mtx 502 -- it'll do about 500+ watts into that sub.... if you're gonna get another momo 104 in the near future, then spring for the mtx 1501D to push the two of them.. well worth the money.The Artist formerly known as PoweredByDodge
whatever you do, dont go with fosgate, they suck ****
hes got the 124, so is the 1501d enough for two of those?It's not good, very fundamentally simply not good. - geolemon
if it puts out around 1000x1 @2ohms, then yes, but i have no idea what its rated
it'll do between 1500 and 1600 x 1 at 2 ohms at 14.4 volts. so ya.... its PLENTY of power.The Artist formerly known as PoweredByDodge
the 1501d can be reviewed at http://www.mtx.com and you can read customer reviews at SoundDomain
it can be bought for $439 at OnlineCarStereo
or for $439 at Alpha Car Audio
or for $429.90 at Discount Jungle (i would throw in the 10 bucks and get it from one of the first 2)
or, if you're crazy, from SoundDomain for $700.It's not good, very fundamentally simply not good. - geolemon
