Amp hum
codyc1ark
codyc1ark Posts: 2,533
edited January 2012 in Electronics
So, I got home this evening and was welcomed to a humming amp. I'm going to unplug it tonight and let it rest, but I haven't switched anything around lately besides some ICs. I'm concerned that this may be a snowball problem, any ideas guys? If it turns out to be a bad transformer or anything of the sort, it'll give me an excuse to send it off to big sky for a complete overhaul. Thanks in advance for any ideas...
Post edited by codyc1ark on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited January 2012
    codyc1ark wrote: »
    Maybe it didn't know the words to the songs.
  • decal
    decal Posts: 3,205
    edited January 2012
    I had the same thought!!!!!!
    tonyb Posts: 33,065
    edited January 2012
    More likely a ground loop.
  • lanchile
    lanchile Posts: 560
    edited January 2012
    is the noise coming out from speakers or the chassis? if you get it from speakers, it can be a ground loop. disconnect all the inputs and see if the noise goes away. many times is some gears that introduce noise to the amp. Ground loops are very common problems. I had the same problem with my cable box that was introducing noise in my amp. I connected the cable box to a filter and the noise went away. as I said before, just disconnect all inputs from your amp and hear if you still have any noise coming out from speakers. the amp should be quiet as a mouse.
    Make it simple...Make it better!
  • Marty913
    Marty913 Posts: 760
    edited January 2012
    Although you did mention you swapped some IC's around recently.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • codyc1ark
    edited January 2012
    lanchile wrote: »
    Hum is from the chassis not the speakers, like I said this just started, and I've tried tondo some digging but haven't come up with a firm answer. I don't think the new ICs should cause a hum from the amp itself, but I'm sure weirder things have happened.
  • lanchile
    lanchile Posts: 560
    edited January 2012
    codyc1ark wrote: »
    ok. open cover and see if that noise is coming from cover or transformer. is the transformer an E (block). CAREFULLY push transformer down and see if noise goes away. you can always "isolate" the transformer with rubber washers to chassis.
