banana plugs
So why do u want bannana plugs so much anyways.... from what I've heard bear wire is better...... but hey I could be wrong.
1- wanna make new jumpers
2-using 12awg wire and theres lots of pressure on the binding post on the yammie affraid it will come loose and short !! -
sure does and thats another reason too!! thanks forgot that one
I found a decent place on the net for speaker connectors and such. Decent quality and reasonable price.
Check it out -
ahhh ic... never thought about that before (maybe cause i dont run 12 awg wire)
