Dumb question of the day
EndersShadow
Can you use a RCA IC in place of a coaxial cable? I will have an extra EXp1 cable. If you can I will use it to replace the cheap Monoprice one I have right now between my computer and the HK3490 in the office.
I apologize for the simplicity of this question, but its Friday and my head hurts lol...
Post edited by EndersShadow on
Some will say yes, so will say no. A coax is supposed to use a tru 75 ohm cable for best performance. I have used a regular RCA and a true 75 ohm RCA and really noticed no difference. So I say yes, try it. You can't harm anything.
I'm assuming you're talking about a digital coaxial cable?
If so, H9 is right, 75 ohms. Some analog IC's are 75ohm; some aren't. It won't hurt anything, and might do great!
The only thing I'd be unsure about in your particular case is the articulation poles in that MIT cable. MIT doesn't use that type of pole in their digital coax cables.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
falconcry72 wrote: »I'm assuming you're talking about a digital coaxial cable?
Gotcha, well I will have some Signal Cable IC's as well (the MIT's are replacing them) so I will give both a shot and see which I like better till I get a USB DAC."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Depends on how close to 75ohm they spec. I CAN tell you that Kimber HERO is an AWFUL digital cable....LOL Talk about flubby bass and rolled off treble...sheesh....and people say bits is bits and wire is wire; you'd have to be deaf to not hear how awful it was. But Hero is fantastic as an RCA analog wire.
If the RCA's are typical coaxial cable (RG-59/58 or RG-6), they should work fine--if they are some other topology---good luck.
Buy you a belden 1694A from blue jeans for $12 and be done with it--it's an EXCELLENT dig cable IME.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Wow, I didn't know you could do this.
Most analog cables vary too much in impeadance to work well with digital. Well--I mean---they'll work, but they can sound like poo-poo.
Digital cables will always work with analog, but not always well the other way around.
STRICTLY MY OPINION:
I've found most coaxial type analog cables to be strident and cold sounding--never cared much for them.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Steve, you are self admittedly deaf :razz::cool::cheesygrin:"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
True Dat! and even I heard it!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Anyone know if Signal Cable's Analog 2's are close to the 75ohm spec? I would be using either one of those or the MIT EXp1.
And no I dont have the MIT's yet so I cant pull the Signals from my rig to test lol....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
It's a coaxial design, so it should work fine.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Rock on. Anythings better than Monoprice
Just FYI, most Component Video cables are 75ohm, because HD video requires higher tolerances. A single Component Video cable will work.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
falconcry72 wrote: »Just FYI, most Component Video cables are 75ohm, because HD video requires higher tolerances. A single Component Video cable will work.
Yeah, only problem is all mine are in sets of 3 (and they are Monster :devil:) so it would be a PITA to run them lol. I think I will just wait and try the Signal Cable one......"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Can you use a RCA IC in place of a coaxial cable? I will have an extra EXp1 cable. If you can I will use it to replace the cheap Monoprice one I have right now between my computer and the HK3490 in the office.
I got one for ya Dan, you have a pm.Testing
Testing
Testing -
Fyi, the custom solidcore silver digital cable pep made me is the best I've heard to date.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
falconcry72 wrote: »Fyi, the custom solidcore silver digital cable pep made me is the best I've heard to date.
He's sending me a surprise.... literally I dont know what brand but if he says its good I will take him at his word
Thanks Ben, much appreciated!
Its not my hand built, but its free and it is pretty good.
I think Dan will be very satisfied with it.:cheesygrin:Testing
Testing
Testing -
Yep, Pep is da man. Have one of his power cables too, just as good as the other upgraded ones I have.
Incidently Pep, just so you know, I voted for you to be Polk member of the year but Heiney[Brock] had his goons rigging the election process ala Saprano style.:cheesygrin: There's always next year bro, you have my vote.HT SYSTEM-
lsi 9's -
LOL!
Thanks Tony!
Brock is a very knowledgeable fellow (more so than myself:cheesygrin:).Testing
Testing
Testing -
They are on my list of tweaks once I get my IC's and wires finalized."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I tried to find out how good they are but I must be on his bad guy list..:eek: -
Not hardly Larry!:cheesygrin:
I always stay a little behind on my cables.
Can't seem to catch up.
Just can't make any promises at this point.:redface:Testing
Testing
Testing -
I know and believe me I understand I only posted to give you a hard time. LOL!! -
Haha you sombitches are a riot!2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Exactly.Depends on how close to 75ohm they spec...If the RCA's are typical coaxial cable (RG-59/58 or RG-6), they should work fine--if they are some other topology---good luck. -
As long as were thread jacking, I'm putting 27% of the blame on my current system issue on Paul, and 73% on ES, ****.
Hey now, I proposed a way to test your system issues to see if its your source or not lol.... I should get CREDIT for how AWESOME your system is going to sound
EndersShadow wrote: »Hey now, I proposed a way to test your system issues to see if its your source or not lol.... I should get CREDIT for how AWESOME your system is going to sound
Errr... I had a typo there, your only getting the small end, Paul gets the big stick! -
