Dumb question of the day
EndersShadow
EndersShadow Posts: 17,687
edited January 2012 in 2 Channel Audio
Can you use a RCA IC in place of a coaxial cable? I will have an extra EXp1 cable. If you can I will use it to replace the cheap Monoprice one I have right now between my computer and the HK3490 in the office.
I apologize for the simplicity of this question, but its Friday and my head hurts lol...
Post edited by EndersShadow on
    heiney9 Posts: 25,398
    edited January 2012
    Some will say yes, so will say no. A coax is supposed to use a tru 75 ohm cable for best performance. I have used a regular RCA and a true 75 ohm RCA and really noticed no difference. So I say yes, try it. You can't harm anything.
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2012
    I'm assuming you're talking about a digital coaxial cable?
    If so, H9 is right, 75 ohms. Some analog IC's are 75ohm; some aren't. It won't hurt anything, and might do great!
    The only thing I'd be unsure about in your particular case is the articulation poles in that MIT cable. MIT doesn't use that type of pole in their digital coax cables.
    edited January 2012
    Gotcha, well I will have some Signal Cable IC's as well (the MIT's are replacing them) so I will give both a shot and see which I like better till I get a USB DAC.
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2012
    Depends on how close to 75ohm they spec. I CAN tell you that Kimber HERO is an AWFUL digital cable....LOL Talk about flubby bass and rolled off treble...sheesh....and people say bits is bits and wire is wire; you'd have to be deaf to not hear how awful it was. But Hero is fantastic as an RCA analog wire.
    If the RCA's are typical coaxial cable (RG-59/58 or RG-6), they should work fine--if they are some other topology---good luck.
    Buy you a belden 1694A from blue jeans for $12 and be done with it--it's an EXCELLENT dig cable IME.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited January 2012
    Wow, I didn't know you could do this.
  • steveinaz
    edited January 2012
    Most analog cables vary too much in impeadance to work well with digital. Well--I mean---they'll work, but they can sound like poo-poo.
    Digital cables will always work with analog, but not always well the other way around.
    STRICTLY MY OPINION:
    I've found most coaxial type analog cables to be strident and cold sounding--never cared much for them.
    edited January 2012
    steveinaz wrote: »
    Steve, you are self admittedly deaf :razz::cool::cheesygrin:
  • steveinaz
    edited January 2012
    True Dat! and even I heard it!
    edited January 2012
    Anyone know if Signal Cable's Analog 2's are close to the 75ohm spec? I would be using either one of those or the MIT EXp1.
    And no I dont have the MIT's yet so I cant pull the Signals from my rig to test lol.....
  • steveinaz
    edited January 2012
    It's a coaxial design, so it should work fine.
    edited January 2012
    steveinaz wrote: »
    Rock on. Anythings better than Monoprice :wink:
  • falconcry72
    edited January 2012
    Just FYI, most Component Video cables are 75ohm, because HD video requires higher tolerances. A single Component Video cable will work.
    edited January 2012
    Yeah, only problem is all mine are in sets of 3 (and they are Monster :devil:) so it would be a PITA to run them lol. I think I will just wait and try the Signal Cable one......
  • Systems
    Systems Posts: 14,873
    edited January 2012
    I got one for ya Dan, you have a pm.
    Testing
    Testing
    Testing
    edited January 2012
    pepster wrote: »
    PM replied...... :wink:
  • falconcry72
    edited January 2012
    Fyi, the custom solidcore silver digital cable pep made me is the best I've heard to date.
    edited January 2012
    He's sending me a surprise.... literally I dont know what brand but if he says its good I will take him at his word :smile:
  • Systems
    edited January 2012
    Thanks Ben, much appreciated!
    Its not my hand built, but its free and it is pretty good.
    I think Dan will be very satisfied with it.:cheesygrin:
    Testing
    Testing
    Testing
    tonyb Posts: 33,065
    edited January 2012
    Yep, Pep is da man. Have one of his power cables too, just as good as the other upgraded ones I have.
    Incidently Pep, just so you know, I voted for you to be Polk member of the year but Heiney[Brock] had his goons rigging the election process ala Saprano style.:cheesygrin: There's always next year bro, you have my vote.
  • Systems
    edited January 2012
    tonyb wrote: »
    LOL!
    Thanks Tony!
    Brock is a very knowledgeable fellow (more so than myself:cheesygrin:).
    Testing
    Testing
    Testing
    edited January 2012
    tonyb wrote: »
    They are on my list of tweaks once I get my IC's and wires finalized.
    Toolfan66 Posts: 17,982
    edited January 2012
    I tried to find out how good they are but I must be on his bad guy list..:eek:
  • Systems
    edited January 2012
    Not hardly Larry!:cheesygrin:
    I always stay a little behind on my cables.
    Can't seem to catch up.
    Just can't make any promises at this point.:redface:
    Testing
    Testing
    Testing
    edited January 2012
    pepster wrote: »
    I know and believe me I understand I only posted to give you a hard time. LOL!!
  • falconcry72
    edited January 2012
    Toolfan66 wrote: »
    Haha you sombitches are a riot!
  • FTGV
    FTGV Posts: 3,650
    edited January 2012
    steveinaz wrote: »
    Depends on how close to 75ohm they spec...If the RCA's are typical coaxial cable (RG-59/58 or RG-6), they should work fine--if they are some other topology---good luck.
    Exactly.
  • codyc1ark
    codyc1ark Posts: 2,533
    edited January 2012
    As long as were thread jacking, I'm putting 27% of the blame on my current system issue on Paul, and 73% on ES, ****.
    edited January 2012
    codyc1ark wrote: »
    Hey now, I proposed a way to test your system issues to see if its your source or not lol.... I should get CREDIT for how AWESOME your system is going to sound :wink:
  • codyc1ark
    edited January 2012
    Errr... I had a typo there, your only getting the small end, Paul gets the big stick!
  • Systems
    edited January 2012
    :biggrin:
    Testing
    Testing
    Testing
