RTi-A9 First Impressions + Break-in Question
ArthurM
ArthurM Posts: 17
edited January 2012 in Speakers
Hi Everyone,
I wrote a long and descriptive review about my new RTi-A9 speakers, but the forum decided to log me out and I lost all of my post. In any case, here is a shortened version....
I am new to the Polk community, both as a forum member and as a customer of Polk products. I took advantage of a great holiday sale in Canada (from Future Shop) and purchased a pair of RTi-A9 towers ($800 for the pair). I am very hopeful that these Polk speakers can be split into a separate 2-channel stereo one day (as I accumulate all the necessary components for a second stereo setup).
My Current 2-Channel Setup
Cambridge Audio Azur 840E Preamp
Carver M-1.5t Amp (completely refurbed and upgraded by Rolland @ Hi-Tech Audio)
Cambridge Audio DAC Magic
Marantz DV8400 Transport + SACD
Tannoy DMT 12 Studio Monitor (Monitor Gold dual concentric drivers)
2 x Velodyne EQ-Max 15 (stereo subwoofers)
Homemade CAT6 speaker cables (bi-wire setup; 4 interwoven CAT6 cables / channel)
First Impressions
After hooking up the Polks and removing the Tannoy speakers, I was shocked at how poorly the Polks reproduce midrage / vocal sounds. The jazz SACD content playing sax and clarinet sounds good, but it's not as real and "believable" as the Tannoy speakers. The Polk's sound-stage and imaging are quite impressive though, even when I'm 20-30 degrees off axis.
Overall, I've put only 10 - 15 hours of "break-in" time on these speakers and I'm curious to know if properly breaking in these speakers will make such a large difference in the quality of the midrange / vocal sound. I'm very perplexed by the large gap I've noticed between other user reviews of these speakers and my own experience.
I've also read that the factory built crossovers in these speakers are made with cheap components, so this may have a large impact on the quality of the sound.
I'd love to hear from other Polk customers, especially those that own the RTi-A9 speakers, because I'm quite disappointed with their performance (especially for an MSRP of $2,000).
Thanks,
Arthur
Post edited by ArthurM on
    tonyb Posts: 33,068
    edited January 2012
    Did you check your speaker connections ? Play around with the settings in the pre ? Try a different speaker cable ? It's a synergy thing sometimes when a new piece gets tossed into the mix. You may have to change up a few things. They will break in over time but not to the extent your describeing. Also keep in mind that the 9's are a HT first speaker, so I wouldn't expect them to be balls out perfect on music. Experiment alittle, give them alittle time to loosen up, before comming to any conclusions. In the end they still may not be right for you, what speaker is for everyone anyway ?
    As a small experiment, change out the speaker cable to any run of the mill 12 ga and put the jumper plates back on the posts in the back of the 9'S and see how it sounds. I assume you removed the plates when you bi-wired with your cat 5 cables. What kind of interconnects are you using from the pre to the amp ? Did you change any crossover settings in the pre when you changed speakers ?
    I'm more apt to believe it's a cable issue seeing that it's only the top half of the speaker thats seems to be muffled some. Make sure no coating from the cables are stuck inside the posts of the speakers. Just some things to consider.
  • 62caddy
    62caddy Posts: 137
    edited January 2012
    Arthur: FWIW - My RTiA7 exhibited the same midrange deficiency as you experienced, although to a lesser extent than what you report. Classical is my primary listening material, which is more midrange-dependant like jazz. I corrected the problem by adding a pair of Snell J7s adjacent to the Polks and the sound is delicious. The Polks replaced a pair of Boston Acoustics T1000 which did a better job in the mid department but the Polk's real forte is their ability to reproduce the bottom end- especially without woofer distortion the B-As exhibited in some material.
    P.S: A prominent loudspeaker engineer defines "break in period" as the amount of time manufacturers/dealers say it takes to get accustomed to bad sound
    Main:
    McIntosh: MC 2155, MC 2125(x2), MR 80, C 32, MQ 101; Snell J7; Polk: RTiA7, RTiA9;
    Pioneer PL-518; A/T 440 MLa; Yamaha CD
    Vintage:
    McIntosh: MX110Z, MC 2505, MC 240, Thorens TD 145; Shure V15III; Altec 14, Boston T1000; Yamaha CDX 393 CD; Yamaha Cass
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    tonyb wrote: »
    Thanks for the feedback Tony. My entire setup, including all cables, is the same during my testing, except for swapping out the Tannoy speakers for the Polks. Also, I keep my entire signal path as flat as possible and use "direct mode" in my preamp because I don't want to EQ the sound. I will experiment and change the cables up and reinsert the crossover bridges on the rear - perhaps the crossover works better without a bi-wire setup (which seems odd to me, but anything is possible).
    Finally, I want to clarify that the midrange / vocals aren't muddy. They are clear and accurate, but they can't touch the "believability" of the Tannoy speakers. Perhaps that's my issue. My reference sound is better than the Polks and the expectations I placed on the Polks just aren't realistic.
    Arthur
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    62caddy wrote: »
    Thanks for the feedback Caddy and I love the line about breaking in speakers! I can understand how mechanical movements can experience a break-in adjustment (like woofers), but when people try and tell that their speaker cables need to break in, I just laugh.
    heiney9 Posts: 25,412
    edited January 2012
    ArthurM wrote: »
    And I get chuckle when people like you don't think cables and other non-mechanical parts don't go through break in. I have heard it enough times in cables, caps, resistors, etc over the past 25 years in this hobby.
  • 62caddy
    62caddy Posts: 137
    edited January 2012
    I know of someone who believes who believes house wiring affects SQ. I suppose that means electric utility lines affect it too. To each his own I guess.
    Main:
    Vintage:
  • tommyt21
    tommyt21 Posts: 685
    edited January 2012
    Things that also affect SQ solar flares, pixie dust & unicorn farts :rolleyes:
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
    tonyb Posts: 33,068
    edited January 2012
    Arthur- Like I said, play around with them alittle, give them some time, in the end they may just not be the speaker for you, who knows. Nothing wrong with that. Good luck to you.
  • clarence carter
    clarence carter Posts: 6
    edited January 2012
    heiney9 wrote: »
    I think "break in", at least in the electrical sense, is being confused with deterioration of electrical parts as they are subjected to heat. Not sure I understand what type of cable would present this problem in an audio setting.
  • m34est
    m34est Posts: 11
    edited January 2012
    I am not familiar with your preamp, but are you using any room correction? If yes, you may need to recalibrate it. If no, it may help.
    It may also be that the synergy among your new setup is not as good as your old equipment. My RTi12s and Onkyo RC 180 together sounded like I had a wet blanket over the speakers until I swapped out the Onkyo for a receiver with better room correction (Anthem + ARC). Now the RTis do a very good job with music.
    edited January 2012
    No confusion here
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    m34est wrote: »
    Thanks very much for the information. I am not using any room calibration. I now understand these speakers need extensive break in so I will continue to work them in and see if it helps. I also have another amp coming in 2 months from now and will experiment with it.
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    edited January 2012
    Sweet, I'll be breaking in a new pair of A9's here shortly next week (upon delivery). Do I dare say I'll be using an Emotiva amp to power them?
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    Geoff4rfc wrote: »
    It seems Emotiva is the amp of choice around here. Be prepared for a very lengthy break in with these speakers. What speakers are you using now?
  • Geoff4rfc
    edited January 2012
    I broke in a pair of 70's, didn't really take that long, I don't expect the 9's to be any different.
    F1nut Posts: 51,700
    edited January 2012
    ArthurM,
    Considering that your Tannoy's are known for their beautiful and liquid midrange, I'm not surprised that you find the Polk's lacking in that department. Even after they break in, I seriously doubt that the Polk's will ever be able to compete. The reality is that you are comparing apples to oranges.
    Is that why you use Cat6? Have you ever tried actual speaker cable?
    Far, really far from it.
  • Geoff4rfc
    edited January 2012
    ArthurM wrote: »
    I agree, far from it, there is a variety of amps that are amp of choice. I currently own an Emotiva and I'd like to be able listen to other amps when opportunity and finance becomes available. Personally, I'd love to to hear what tube amps do for music.
    tonyb Posts: 33,068
    edited January 2012
    Geoff4rfc wrote: »
    Oh, don't do that. It's a rabbit hole from which there is no escape.:cheesygrin:
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    Hi F1nut - I actually know you from the Carver forum and really respect your posts. I have never said that speaker cables are all built the same. I'm just saying that breaking in speaker cable is nonsense to me. If anyone can rationalize the difference in a quasi-scientific and meaningful manner, I'm all ears...or eyes in this case. I have 12 guage speaker wire in the basement and have used it extensively. But I'm using the CAT6 cables because the 4 twisted solid copper pairs of wire in each single cable helps to minimize inductance significantly. I need 4 cables/channel because one cable with 4 twisted pairs doesn't provide me with enough copper to push the required current.
    And you're probably right. I'll never get Tannoy-like midrange purity out of the Polks.
    Arthur
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    Geoff4rfc wrote: »
    Well, I'm going to unleash the Carver amp on these speakers and break them in even quicker. Plus, I don't mind listening to music a little louder when draining a few pints :-).
  • Geoff4rfc
    edited January 2012
    tonyb wrote: »
    Are you serious?????? I fell down this rabbit hole miles ago. There is no turning back, I just keep going toward the light.
    ArthurM wrote: »
    I do mostly movies, but I really enjoy popping in a CD from time to time. I love having a few cold ones as well and I totally love the sound of my 70's on roids. But as Tony pointed out, I'd just be swinging from one vine to another if I decided; "Hmmmm, I wonder what kind of music room I could put together?"
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    Geoff4rfc wrote: »
    Having a dedicated audio room with a sizable bar is definitely a life goal for me. Nothing beats hanging out with a couple of buddies and listening to music at 200 wpc while pouring beer from a tap! BTW, how do you like the Epik subs? I was thinking about buying them instead of the Velodyne, but I couldn't get them shipped into Canada. Do they pound hard...and I mean hard?
  • Geoff4rfc
    edited January 2012
    ArthurM wrote: »
    Having a dedicated audio room with a sizable bar is definitely a life goal for me. Do they pound hard...and I mean hard?
    I totally lucked out with my set up. The downstairs came with a wet-bar, you would love it. I'll show you a picture.
    The Epik Empire, oh my gosh! My H.T. area measures out to 15.5 X 26 ft. including and up to the wall behind the wet-bar, I have another 12ft to the right of the H.T. area where my movies are kept and now has a foosball table.
    On the sub, I have the volume knob set on 1/3. I bounce back and forth between 1/4 and 1/2. When it's on half volume, my wife gets so pissed off, she's ready to kill me, the whole upstairs shakes like an earthquake, I love it.
    I still need some room treatments like bass traps for sure, I move the sub around periodically to see what comes of it. I'm fixin to move it back behind the seating area to the wall next to the bar as soon as my 9's show up.
    I'm almost wishing I got a pair of Legends instead of the Empire......naw. One day I'll get a second Empire.
  • ArthurM
    ArthurM Posts: 17
    edited January 2012
    Geoff4rfc wrote: »
    I totally lucked out with my set up. The downstairs came with a wet-bar, you would love it. I'll show you a picture...
    That's an awesome setup! I'd be in that room right now draining some beer and watching sports.
    Also, I'd love to listen to the Epiks one day because I've heard nothing but good things from their series of subs.
    F1nut Posts: 51,700
    edited January 2012
    ArthurM wrote: »
    Hey Arthur,
    I'm far less concerned with the science, preferring instead to rely on what my ears tell me. I guess it boils down to it's one of those things that you have to experience for yourself.
    BTW, welcome to Club Polk.
    edited January 2012
    ArthurM wrote: »
    Emo is entry, nothing more, nothing less
